stuck in first gear... Stranded!!
Re: stuck in first gear... Stranded!!
Postby jay » Mon Jun 14, 2010 10:49 pm
ford mt75 box dont fit on a pug engine didnt someone over on the ldv forum try it(I joined when i had a ldv400 and a convoy)they found it didnt fit on the engine at all unless you made a adaptor plate up but the gearstick was further back..check a convoy and ldv400 and you will see the stick is firther back towards the cab by about 6 inches..
mk1 connect tourneo
jay
Postby bazw » Mon Jun 14, 2010 11:29 pm
Altransit wrote:Are you sure Baz :?
Jas wrote: Reverse is by pulling up lever on the gear stick shaft and then down to bottomright below 5th.
hang on a mo , we talking about the box i was looking at or the problem one jas has here ?
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby tim » Mon Jun 14, 2010 11:47 pm
The pug engined Convoy had a MT75 box,i know that for sure
A WORK OF ART IS A JOY FOREVER
tim
Postby Altransit » Mon Jun 14, 2010 11:50 pm
tim wrote:The pug engined Convoy had a MT75 box,i know that for sure
Oooooh .............. new information :D
Thanks Tim 8)
Postby tim » Mon Jun 14, 2010 11:57 pm
The mt75 box was fitted to LDV Convoys from sep 1996 to Pug EN/ET and Ford Di engines,I have just got this info from my servive disc
tim
Postby AndyG » Tue Jun 15, 2010 12:00 am
But we're talking 1994 here :!:
Postby tim » Tue Jun 15, 2010 12:07 am
Are you sure its a Ford Engine,Which side is the injector pump on,Pass or drivers
tim
Postby Altransit » Tue Jun 15, 2010 12:09 am
It's defo a pug engine, the question was about the box being an MT75, or not :D
Postby tim » Tue Jun 15, 2010 12:12 am
Sorry about that.On about 3 forums at the moment.Give me 5 minutes
tim
Postby tim » Tue Jun 15, 2010 12:33 am
Right i have it right this time.All 400 models with the En/Et Pug engines had the P5_100 box.After 96 the En/Et pug engines had the MT75 and single rail box.If your box has gear linkages its the p5-100.Come to think of it i had a Citroen relay van many years ago and had problems with gear linkage,if one of the little ball joints came loose it would stay in that gear no matter what you done.I have disc here with everything about the box but havent a clue how to download it.If you have any idea how you do it your welcome to it other than that its the snail mail
tim
Postby bazw » Tue Jun 15, 2010 12:59 pm
tim if you download this prog
http://www.utorrent.com/downloads
( top one)
then install and follow instructions for "making a torrent " you can post it to a torrent share site and we can get it
on a scale of 1-10 its around a 3 or 4 i would say as comp progs go
also not a bad way to pick up other files and stuff :wink:
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby tim » Wed Jun 16, 2010 9:25 am
bazw wrote:tim if you download this prog
( top one)
PM sent
tim
