Does it have a Timing Belt or Chain?
Postby ake » Mon May 17, 2010 6:33 am
Timing Chain Timing Belt Cam Chain Cam belt TimingChain TimingBelt CamChain Cambelt
MK1
1.7 & 2.0 essex V4 - fibre gears
1.5 & 1.7 cologne V4 (German vans only) - fibre gears
1.6 crossflow - chain
Perkins 4/108 1752cc - Gear driven
2.4 York - belt
MK2
2.4 York - belt
2.5 Di - belt
2.0 & 1.6 pinto - belt
3.0 essex - fibre gears
MK3
2.5 Di - Belt 70ps
1.6 & 2.0 Pinto - Belt
3.0 Essex V6 - fibre gears
2.9 Cologne V6 - chain
MK4
2.5 Di and TD - Belt 70ps, 80ps, 100ps
2.0 Pinto - Belt
2.9 cologne V6 - chain
Mk5
2.5 Di and TD 70ps, 76ps, 85ps, 100ps, 115ps- Belt
2.0 Dohc - chain
Mk6
2.0 TDDi 75ps, 85ps, 100ps - Chain
2.0 TDCi 125ps - Chain
2.4 TDDi 75ps 90ps 115ps 120ps 125ps - Chain
2.4 TDCi 135ps - Chain
2.3 Dohc - chain
MK7
2.2 TDCi 85ps 110ps 115ps 130ps 140ps - Chain
2.4 TDCi 100ps 115ps 140ps - Chain
3.2 TDCi 200ps - Chain
2.3 Duratec-HE (M14) - Chain
MK8 & Custom (up to 2016ish)
2.2 TDCi Euro 5 TDCi Engine - Chain
MK8 & Custom (from 2016ish)
2.0 TDCi Euro 6 TDCi Engine - Wet Belt
Connect
1.8 TDDi/TDCi - Chain and Belt (2010 Models Have wet belt instead of chain)
1.8 Zetec - Belt
Re: Does it have a Timing Belt or Chain?
Postby SirKit Breaker » Wed Jun 16, 2010 8:01 am
Ake,
interesting post, can you please explain what a wet belt is .
Cheers........Howard
SirKit Breaker
Postby ake » Wed Jun 16, 2010 9:04 pm
Not really sure, But I'm sure one of our Ford Technicians could enlighten us :)
Postby coconut » Wed Jun 16, 2010 11:19 pm
Basically a wet belt is like a cambelt but it runs in oil
coconut
Ford Technician
Postby Mastertech » Wed Jun 16, 2010 11:39 pm
Yes the latest connect has now gone to a wet belt instead of the chain on the lynx engine.
Mastertech
Ford Technician
Postby AlanN » Thu Jun 17, 2010 12:08 am
I thought all Cologne's had fibre gears
Postby MrMPuk » Tue Jun 22, 2010 7:55 pm
[quote="AlanN"]I thought all Cologne's had fibre gears[/quote]
http://en.wikipedia.org/wiki/Ford_Cologne_V6_engine#2.9
Postby AlanN » Tue Jun 22, 2010 9:07 pm
Thanks Mike, didnt know that...
Postby Davidreidy » Wed Jul 27, 2011 8:23 am
Does that mean because it has a chain it wont snap or could they still snap because i know if the belt snapps it can reck your engine?
cheers.
Davidreidy
Postby Altransit » Wed Jul 27, 2011 8:57 am
A chain can snap, but it's unlikely, unless you ignore the loud clattering noise that it will probably make for a long time before that happens.
A belt doesn't usually give any warning!
Postby longy » Wed Oct 31, 2012 10:19 pm
My chain jumped a cog or two then pulled out Rocker gear hold down bolts. No warning just stopped....
longy
Postby gus-lopez » Thu Jan 23, 2014 8:40 pm
am I right in thinking the chain needs replacing at certain intervals ? I'm sure I read it somewhere . It's just that I'm looking for a van at the moment & most adverts here are saying 'chain, no maintenance needed'. makes me wonder about the fsh.lol
gus-lopez
Postby enaboy15 » Sat Mar 15, 2014 4:09 pm
hi ,the 2009 t330 100 swb, rwd, thats the 2.4,would that have a chain or belt ? be grateful if you can help,thanks paul
enaboy15
Postby ake » Mon Mar 17, 2014 8:12 am
enaboy15 wrote:hi ,the 2009 t330 100 swb, rwd, thats the 2.4,would that have a chain or belt ? be grateful if you can help,thanks paul
According to the information at the start of this thread, all MK7 have chains.
Postby Softlips » Wed Feb 11, 2015 8:42 pm
What does the custom have!
Softlips
