Hill start assist
Hill start assist
Postby Grenadekid » Mon Jun 21, 2010 10:26 pm
FordService
Generate a FordService schedule
Vehicle Conversions
Body & Equipment Mounting Manual (BEMM)
Parts Catalog
http://www.fordecat.com
Outstanding Field Service Actions
7W131 - TRANSIT - RECHARGEABLE REMOTE KEY.(CUSTOMER COMPLAINT BASIS ONLY)
* Illustration shows model only
Transit (V347/348), 2.4L Duratorq-TDCi (115PS) - Puma, Frozen White
VIN Number: WF0XXXTTFX7E48048
Registration Number: BT07OAP
Registration Date: 29.06.2007
Registration Country: GB
Primary Features
Build Date: 20.04.2007
Vehicle Line: Transit (V347/348)
Cab Style: Regular Cargo Van
Series: 350E Series
Engine: 2.4L Duratorq-TDCi (115PS) - Puma
Transmission: 6-Speed Manual Tranmission - MT82
Drive: RHD RWD
Axle Ratio: 3.73
Emission: Stage IV Emissions
Territory: (+)"GB"
Paint: Frozen White
Interior Fabric: Tomy (G-C)
[Click to collapse]
Minor Features
* With High Roof
* High Door Height
* With Full Partition - Steel
* With Hinged Rear Loading Doors
* With 256° Cargo Door Check Arms
* With Magnetic Rear Door Catch
* Otosan (Turkey) Plant Build
* Marketing Level 3
* European Environmental Label
* With Manual Front Windows
* With Clear/Light Tinted Glass
* With Rear Blanking Panel
* With Black Air Vent Knob
* With Partial Headlining - Moulded
* With Load Space Tie Down Loop
* With Cargo Stowage Rail (Mid)
* With Rear Step - Centre
* Large Head/Short Arm Mirror
* With Drivers Seat Fixed Armrest
* With Driver 6 Way Mnl.Seat Adjuster
* With Front Towing Hook
* Fleet Key
* With Door Dead Locks
* With Door Entry Remote Control Unit
* With Spare Tyre Security Package
* With Single Rear Wheels
* Cold Start Up To -20%c
* With Tunnel Mounted Parking Brake
* Power 4-Wheel Disc Vacuum Boost
* 4 Wheel Anti-Lock Braking System
* Electronic Stability Brk Ctrl (ESP)
* With Sngle.L/B Dvr/Dual L/B Pass.St
* With Recirculating Heater
* Fuel Water Separator Less Sensor
* With MPH/KMH Speedo
* Extra Heavy Duty Battery
* With Radio Pre-Equipment Pack 1
* ICE-Low Level CD + AM/FM Radio
* Ice Feature Pack 2
* With High Mounted Stop Lamp
There are more minor features for this vehicle, click to expand this list.
©Copyright, Ford Motor Company 1994 - 2010 | Privacy Policy
Can anybody tell me if this van has hill start assist fitted thanks
At home
05 220 tdci connect (remapped to 115)
94 toyota rav4 2.0 petrol
2011 kia sportage kx3 2.0 diesel
2001 RAV4 NG
Grenadekid
Re: Hill start assist
Postby ake » Tue Jun 22, 2010 6:37 am
Dont think so was 2008 on I think
Postby Vee4 » Tue Jun 22, 2010 12:50 pm
HLA is mentioned in my April 2008 brochure, but not in the 2007 brochure (dated September 2006). Presumably, you ask because you can't try the van. If HLA is fitted, there is a warning light showing a van (looks like a Connect) on a slope.
'69 Mk1 V4 :) >> '76 Mk1 V4 :) >> '84 Mk2 OHC :wink: >> '97 Mk5 Banana :D >> '09 Mk7 TDCi 8)
The van in front is a Transit. It might be my Mk7 - follow the trail of rusty water: Diary of an Ordinary Van
Vee4
Postby sportacus » Tue Jun 22, 2010 4:39 pm
my 2006 transit has just been remapped by vantuner, martyn upgraded the software to latest and it now has HSA :D
115T280 sea grey limited
iv'e now killed 2 mk7 engines and a mk6, is that a record ?
sportacus
Postby Vee4 » Tue Jun 22, 2010 5:48 pm
sportacus wrote:My 2006 transit has just been remapped by vantuner, martyn upgraded the software to latest and it now has HSA :D
That's interesting. Presumably, there is no warning light?
Vee4
Postby sportacus » Tue Jun 22, 2010 6:06 pm
no light but it is there, works a treat :D
sportacus
Postby uksoftware » Tue Jun 22, 2010 7:53 pm
Now that is interesting.
Can he do a 140 Jumbo 2007 plate? (I suppose I should just ask him, I`ll do a search).
uksoftware
Postby Grenadekid » Tue Jun 22, 2010 8:34 pm
thanks guys checked it today no warning light so i guess its not on it
At home
2001 RAV4 NG
Grenadekid
Postby uksoftware » Sat Jun 26, 2010 7:32 am
Could somebody explain how Hill Start Assist works? Does the van just know when to enable it or do you have to manually turn it on?
I`m trying to work out how it works with manual transmission, do you just floor the accelerator and release the clutch, so that HSA can control it or what? (just very curious).
Thanks.
uksoftware
Postby ake » Sat Jun 26, 2010 8:43 am
If the van is in gear and on an incline, and the clutch and brake are depressed, when the brake is released it holds the brake on for about a second before they release, to give you time to bring the clutch up to bite.
Postby mike.T » Sat Jun 26, 2010 9:19 am
uksoftware wrote:Could somebody explain how Hill Start Assist works? Does the van just know when to enable it or do you have to manually turn it on?
Thanks.
Hi
My built 7/10/2007 T350 130 5 speed model has this fitted and works well , on a steep hill the brakes stay on for 2-3 sec's when you have removed you foot to allow you time to get you foot on the accelerator and the green logo on the dash lights up .
Mike
mike.T
Postby sportacus » Tue Jun 29, 2010 7:16 am
now i know what it does mine is not HLA its anti-stall, which is still handy as it wasnt there before :D
sportacus
Postby Vee4 » Mon Jul 05, 2010 10:01 am
There's some more info here:
viewtopic.php?p=459895#p459895
Vee4
Postby loot » Tue Jan 13, 2015 7:02 pm
I got nothing so far :cry:
07 350 170ps
Ids map here
loot
