tonys smiley swb 80 cosworth v6
Postby rover » Thu Jul 13, 2006 9:12 pm
I would say second hand you should be looking at about £30 for the complete thing, I can buy the pump new on its own for £58, but I think I have only ever replaced two, and they were both through abuse...as in the filters were never changed!
Yeah Mk3 2.0 16V.
Rover.
rover
Postby OxtonyxO » Thu Jul 13, 2006 9:25 pm
thanks rover :D :D
OxtonyxO
Postby OxtonyxO » Sat Jul 15, 2006 6:58 pm
fitted the front central locking today and it works!! was very easy
however when i removed the trim from the footwell passenger side i had a big hole :roll:
so out with the welder again :!:
also lifted the carpet from the drivers side to find it wet :?:
so clean all that up and painted it with white hammerite cant see where water would get in
not alot of water so could it have come in off my feet and gone down the split rubber and just sat there as ive only done 700 mile since jan
also won a fuel pump and filter off ebay
OxtonyxO
Postby OxtonyxO » Wed Aug 16, 2006 6:52 pm
hi all not been on for a while (lost my internet bloody ntl)
been busy with the van
ive sprayed and the rear doors and fitted the windows
cut the hole in the sliding door and prep for spraying
and best of all ive fitted the cossy engine (almost)
got a list of parts i need to get it running including a proper set of engine mounts which i am making at the moment
as for fitting the engine was easier than i was expecting
only problem is the power steering need a hose making
and here is the pics
and my temp mounts just to get the engine in the right place :D
OxtonyxO
Postby Nathan_Cardiff » Wed Aug 16, 2006 7:19 pm
I find it funny as you keep saying how easy most things are to do, im not to bad with mechanical problems but woudlnt attempt most of what youve done. good on you.
nice one :D great pics.
52 SWB Transit
Nathan_Cardiff
Postby AndyG » Wed Aug 16, 2006 7:22 pm
That engine looks so 8) 8) 8) 8) 8) wicked :!: :wink:
Postby Transitwalla » Wed Aug 16, 2006 9:12 pm
Nice work dude :wink: that engine looks the biz sat in there . . . and aint it funny how easy things are when you've done them :) :wink:
Imagination....our only limit....
there's no such thing as a daft question.
Jim.
Transitwalla
Postby OxtonyxO » Sun Aug 20, 2006 7:29 pm
rain has stopped me doing much today sooo
i spayed the rocker covers and plenum
will have to see how long to paint stays on with the heat :shock:
OxtonyxO
Postby pce-hq13 » Sun Aug 20, 2006 10:56 pm
did you use hi-temp paint or normal spray paint....
paul
EDIT: i suppose with hi-temp paint a primer may be necessary !!!
pce-hq13
Postby OxtonyxO » Mon Aug 21, 2006 7:07 pm
i primed it with celly and then gave it two coats off black industrial gloss black celly
have to wait and see if it flakes off then i will have them shot blasted and polished :D
OxtonyxO
Postby OxtonyxO » Sat Dec 09, 2006 5:45 pm
hello all im back
have been off line for a while
well not much has happen since my last post have been very busy at work
however i do have a problem i need to find some where that sells coolant hoses
and a new edis unit as my brother droped mine a nd broke
has any one got theres running yet?
OxtonyxO
Postby madmark » Sat Dec 09, 2006 5:51 pm
speak to guy88 he is good with this conversion! :wink:
Postby Guy88 » Sat Dec 09, 2006 5:58 pm
madmark wrote:speak to guy88 he is good with this conversion! :wink:
No im not :oops: :oops: :oops: Mines not injecting properly at the moment. (wiring issues) :roll:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby OxtonyxO » Sun Jan 14, 2007 4:37 pm
been out playing to day
refitted the plenum
fitted the exhaust manifolds
sort the brakes vacuum pipe
fitted the throttle cable
then went to fitted the coil pack and hit a snag
there not enough room cause of the bulk head will have to adjust that later
and thanks to some photos from valsheda i now know that the dohc rad fits the 24v pipe work and it has electric fans :D
on a down side they cost £135 new :(
OxtonyxO
Postby Guy88 » Sun Jan 14, 2007 6:05 pm
OxtonyxO wrote:been out playing to day
refitted the plenum
Im happy now :D :D
Its not just mine that bont fit 8) 8) Just bolt it to the bulkhead above the mount :wink: :wink: There is a strengthening bar behind the bulkhead there :x
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
