1999 Tourneo 2.5TD
1999 Tourneo 2.5TD
Postby benarroch » Thu Jul 15, 2010 12:34 pm
Hi
Does anyone know what the correct tyre size is for this vehicle. I have 185/65 R14 C. Is this correct and what is the correct tyre pressure
benarroch
Re: 1999 Tourneo 2.5TD
Postby trigger » Thu Jul 15, 2010 12:37 pm
My old 99 Tourneo had 185 x 14 but i don't think it really matters, my current mk5 van has 205 x 14's on Tourneo rims
Mk5 Transit the daddy
trigger
Postby ripbuster » Thu Jul 15, 2010 12:47 pm
Thats a low profile for a 14. I think they should be 80 profile or straight 195/14 205/14.You are on a lower profile of 15% of 195.As long as they are commercial they will be fine but will look smaller in the arch.
Are all the tyres 195/65/14?
ripbuster
Postby Luke » Thu Jul 15, 2010 6:52 pm
185/80R14c or 185R14C (the same) is a correct tyre for a transit but i thought all the tourneos came with 195R14c's from the factory - i wouldnt change them for the sake of it tho only fit new 195s when the 185s are worn out :D
Postby AndyG » Thu Jul 15, 2010 10:10 pm
Steel wheels 195x14
Alloy wheels 205/70x14
Postby benarroch » Fri Jul 16, 2010 7:08 am
but why is alloy bigger than steel?
I have alloy, is it safe to continue with 185/65/14
benarroch
Postby Altransit » Fri Jul 16, 2010 8:58 am
You don't have to use the bigger tyres on the alloys, mine has 195/14's on Tourneo alloys :D
I would say that as long as the tyres you have on there are correctly weight rated for the van, then they should be OK. If not, then it's a potential MOT fail :shock:
Postby Luke » Fri Jul 16, 2010 1:57 pm
benarroch wrote:Thanks
if they are 185/65/14C then they should be fine - its an odd size do they look like rollerskate wheels :?: :D
Postby AndyG » Fri Jul 16, 2010 8:20 pm
Ford deliberately fitted the Tourneo alloys with 205/70x14s because being slightly wider meant that they could be run at lower pressures and give a softer ride :)
Postby psv-hgv-flt » Sat Jul 17, 2010 8:02 am
Andyg wrote:Ford deliberately fitted the Tourneo alloys with 205/70x14s because being slightly wider meant that they could be run at lower pressures and give a softer ride :)
yeap 205/70/14 and handle road a lot better.
psv-hgv-flt
