2002 2.0 tdi water pump help
Postby mjsroofing » Wed Sep 08, 2010 9:32 am
Hi, I am new to this site,
i've owned my 2002 100 ps 2.0 tdi 280 transit for 4 yrs with no problems and i've serviced it every 5k, its on 150k now and the water pump has just started leaking, i've picked up a new one and was just wondering bewfore i tackle it if any of you had any good advice for me.
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Re: 2002 2.0 tdi water pump help
Postby mjsroofing » Wed Sep 08, 2010 10:42 am
could really do with some help here.
mjsroofing
Postby angeleye » Wed Sep 08, 2010 2:50 pm
what sort of advice are you looking for,
you will also need new gasket and "O" ring
simply enough job
drain coolant,
remove power steering pump drive belt
remove inlet manifold
remove air intake hose
four bolts for coolant support bracket
take bolts out of power steering pump connected to coolant pump and place out of the way
take coolant hose of pump
take bolts out of coolant connecting it to block (wiring is connected to one of the bolts
take pump out and remove other hoses
throw away gasket
take off oil tempreture thermostat and throw away "O" ring
use correct coolant when refilling
when refilling fill to max on expansion tank replace cap start engine until normal temp is reached idle engine for a few minuetes ...then let engine cool for 30/40 mins then refill expansion tank to correct mark,check again atfer a decent drive and letting cool down
do use correct antifreeze/coolant (red)
maybe a good idea to do a flush thru while your at it
angeleye
