This side is not that bad apart from just by the rear wheel arch i didnt notice anything until i sanded a little bit of rust off the arch and noticed it had filler about an inch thick to fill a dent so i used my slide hammer to get most of the dent out and now just have a tiny bit of filler on there.
This wing badly mangled so have a wing from a van my mate was splitting ready to go also the grill part under the lights is cracked i dont know wether to try and fix it or buy a nother panel.
This side is by far the worst took me 3 full days just knocking dents out and filling and sanding then filling and sanding again. When i was sanding this bit i noticed a small crack in the paint on the bottom of the side loading door so sanded it a little bit to reveal another tonne of filler i havent managed to get around to this bit yet but im thinking it might be easy to just get another door saves all the hassle but im in 2 minds about this so will decide next week.
Rear doors not that bad just a couple of dents sort of filled but not finished.
Next the roof it was very badly dented so with my panel beating tools i bought off ebay i set off knocking them out this is just the first go at them i will get it better than that then fill whats left.
Thanks for reading
