MK3 power steering
MK3 power steering
Postby Guy88 » Wed Jul 26, 2006 10:53 pm
As i am now about to fit power steering to my MK3 i have a few questions
1. the pump bracket is off a diesel transit. Is it hard to modify it to fit a pinto?
2.Is there a nack to bleeding it up or is it just a case of starting it up and turning the steering
3. as its dark and im too lazy to look is there a double pulley on the engine to take the pump? or is it a longer fan belt job :?
Pipes are not a problem as i am getting new flexi ones made up for me :D
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby 100ps_drw_hicube » Wed Jul 26, 2006 10:54 pm
double pulley :wink: :D
100ps_drw_hicube
Transit Abuser!!
Postby Guy88 » Wed Jul 26, 2006 10:56 pm
That makes it easier then 8)
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Wed Jul 26, 2006 11:06 pm
As for bleeding it you need to go lock to lock a few times then hold it on full lock for a bit then hold full lock the other way.
Postby Guy88 » Wed Jul 26, 2006 11:09 pm
2 out of 3. just the bracket now :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Wed Jul 26, 2006 11:10 pm
On that you'll have to see what you can do!
Postby captain hook » Wed Jul 26, 2006 11:57 pm
I need a diesel pump and bracket for my conversion but.......
I have a Petrol PAS pump,bracket,double pulleys etc
A Swap maybe???
captain hook
Postby transitgeoff » Thu Jul 27, 2006 7:00 am
Guy88, you wanna take up that swap offer even if you have to buy the diesel bits as the petrol stuff is much rarer, id be surprised if yours has a double pulley on the crank :?: :D
transitgeoff
Postby rover » Thu Jul 27, 2006 8:35 am
Even if it has a double pulley on the crank the chances are that you wont have the pulleys for the alternator and water pump :?
Do the swap mate, it will make things a lot easier :D
Rover.
rover
Postby Guy88 » Thu Jul 27, 2006 5:28 pm
I have sent a PM :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby captain hook » Thu Jul 27, 2006 10:31 pm
And I've answered it!!!
captain hook
Postby dangeeeeerousss » Fri Jul 28, 2006 2:29 am
if this helps any i can get the full powersteering kit rack pump, brackets,ect £100 s/h of course but in full working order i priced the bracket up at my local ford dealer he said its a 2 piece bracket which i new one was around £85 and for the other it was around £60 so god knows how much it would of cost for everything
if anyones interested let me know
cheers
dangeeeeerousss
Postby rover » Fri Jul 28, 2006 8:00 am
Sounds a bit pricey considering I paid £50 for the complete setup from Tony at 'Midniteclassics' On the other hand could you ask your mate how much for a petrol rack and pipes and a valve from the pump, I already have the pump and all pulleys etc but had to nick the valve from the pump for my V6.
Rover.
rover
p/s
Postby spanners » Fri Jul 28, 2006 10:07 pm
hi i did this on my van changed to double pulleys the rack i used a granada p/s pump and bracket works well :lol:
spanners
