stevenstead wrote:My SatNav requires the speed pulse wire connected or it clearly states in bold that the unit will not function correctly.
One suggestion on this forum states its on the black plug on the rear of the instrument panel, pin 6 (blue/white wire). Not sure if this is for a particular Mk?
If you are unable to find it (or risk the wire above), my manual suggests a speed pulse generator (Pioneer ND-PG1).
Not sure what to do with my Mk6 now, don't fancy being ripped off further trying to get functionality out of this damn stereo lol.
qplumb wrote:stevenstead wrote:My SatNav requires the speed pulse wire connected or it clearly states in bold that the unit will not function correctly.
Fitted a becker traffic pro and speed pulse on a mk6 is the 6th wire down on the right plug behind instruments,works a treat
stephenferguson wrote:Hi
Ive come over from the transit connect section as i have an 06, older shape, t280 tranny now. I am desperate to find the spped pulse wire on this. Has anyone found it yet?
regards stephen.
MrMPuk wrote:Hasn't qplumb answered that above already?
robsbird wrote:my mk6 125 i put it in a car audio shop could not fit the ford sat nav as they could not get speed pulse
but i fitted it and picked up speed pulse off gear box Blue/white worked fine for the 3 years i had it
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
