A series engine Help
Ford A-series 1974 - 1982
Postby A Beast » Tue May 18, 2010 6:23 pm
I have a A series RB44 with a 4 cylinder engine, turbo and a Minimec inline pump. Is this correct? the engine looks like the six cylider in a D series but shorter. Would this be a 2.5 or a 3.5?.
It came to me as forestry crane and just to confuse things it has has the cab of a VW LT 35. so we call it the UNIDOG
A Beast
Re: A series engine Help
Postby madmark » Tue May 18, 2010 6:31 pm
it sounds like a york 2.4cc :wink:
Postby A Beast » Tue May 18, 2010 6:48 pm
madmark wrote:it sounds like a york 2.4cc :wink:
Is the Turbo Stadard :?:
A Beast
Postby madmark » Tue May 18, 2010 6:52 pm
no mate not attal,never seen a turbo york,but if you say minnimec pump then that was oftern fitted to the york engine! :wink:
have you got a photo?
Postby A Beast » Tue May 18, 2010 8:09 pm
I'll ty an get photo posted tommorow. closer look suggests turbo not original. The vehicle didnt have a exhaust when i got it. Never bean regestered on the road and I dont suppose the trees bothered about the noise in the forest :P
A Beast
Postby madmark » Tue May 18, 2010 9:40 pm
:lol: :lol: :lol: :lol:
Postby manandvan » Fri Oct 01, 2010 6:12 pm
hi ive never seen a turbo on a 2.4. york engine! you say it looks like a ford d engine but shorter? it could be a 4cyl d series engine which does have the minimec pump also, i would know it if i saw a picture, if it is then it is 4.2 litre and the turbo has been added. :D
manandvan
Postby peter1975 » Sat Oct 02, 2010 12:39 am
YORK 2.4 when i used to drive a series with that lump the only way it would start was with easy start :?
if aint broke still fix it
peter1975
Postby billybun » Thu Jan 13, 2011 2:16 am
3.5 has 6 pots :D
billybun
Postby billybun » Thu Jan 13, 2011 2:19 am
s
peter1975 wrote:YORK 2.4 when i used to drive a series with that lump the only way it would start was with easy start :?
the last york ...... one that had a glow plug in each pot started straight away,early ones it was found the timing marks where not spot on on the crank and by playing about a couple of teeth on the belt you could get it to go off the glow plug with no easy start :D :D
billybun
Postby oldyellar » Thu Jan 13, 2011 7:12 pm
Saw a work engined mk1 camper on ebay last year it had a turbo added to it :?
oldyellar
Postby manandvan » Sun Jan 16, 2011 4:03 am
i,m working on the fact that in his original post he says it looks like a d series engine but shorter, there was a 4 cyl version 255 engine of the dorset series.
manandvan
Postby manandvan » Sun Jan 16, 2011 4:04 am
in theory the 2.5 d.i. turbo would bolt straight on to the york engine.
manandvan
Postby A Beast » Mon Jan 31, 2011 5:34 pm
Hi all thanks for the posts,
I have bean busy so not had much time on the Beast.
The engine was a 4 cylinder York in a RB 44. We have replaced the engine with a Perkins 4203 and ZF Box, The Renolds Baughton transfer box was shot so it has bean replaced with a transfer box out of a late dodge 50 RB 44 a bit of a chop and weld job and shorten a prop.
If all goes to plan the chassis and running gear will be done soon and it will probbably end up with the Crewcab of a LDV convoy and a Hiab.
It is a Hienz 57 ford A series hence it gets called the UnIdog of my mates :lol:
A Beast
Postby manandvan » Tue Feb 01, 2011 11:58 pm
you should speak to woodseller on here, he,s got an rb44, you 2 could probably help each other. :)
manandvan
Return to Ford A-Series
