MOT question
Re: MOT question
Postby dodgy01 » Sat Oct 02, 2010 7:32 pm
oh i thought it had passed
why are you confused buddy
if the corrosion was excessive and with in 30cm of that brake load sensing valve in your picture then it should have failed on brakes as i said in my prevous post
basically you have to imagine a ball shape of 30cm with the outer edge on the area of corrosion if you where able to rotate it fully all round that piont then evrey thing in that area is taken in to account ie shock mounts brakes , suspension and so on
dodgy01
Re: MOT question
Postby Guy88 » Sat Oct 02, 2010 10:37 pm
theres a hole in the second pic about 6" from the shocker bolt, surely this is a fail :?:
and the sill is 5" from the tyre
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: MOT question
Postby Mikey B » Sat Oct 02, 2010 11:06 pm
Should have failed on the hole by the shocky mounting. Wont fail on a hole in the floor you could have no floor in the back at all, as long as the chassis is in tact as it seemed to be around the LAV.
Its different on a transit as it has ladder frame chassis unlike a car that can fail with a hole in the floor. As for the sill i cant think if there is anything around the area it can fail on.
MKB Autos All makes and models catered for.
Mikey B
Ford Technician
Re: MOT question
Postby dodgy01 » Sun Oct 03, 2010 9:28 am
it will fail in the hole in the floor if it is within the pescribed area
just to confirm this i have a guy here called peter wiggins who is a vosa inspector and trainer
he agrees with me that the hole in the floor will fail if it is with in the pescribed area ie 30 cm of the brake load sensing valve
dodgy01
Re: MOT question
Postby Guy88 » Sun Oct 03, 2010 9:42 am
didnt get a mention about floor near shocker on the fail
Had my old MK3 fail on the sill being next to the tyre,
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: MOT question
Postby dodgy01 » Sun Oct 03, 2010 10:00 am
good luck mate
dodgy01
Re: MOT question
Postby Mikey B » Sun Oct 03, 2010 12:43 pm
Rather than argue im going to agree to dis agree. Each tester to there own lol..
Good luck with the mot.
Mikey B
Ford Technician
Re: MOT question
Postby maycontainnuts » Mon Oct 04, 2010 8:52 pm
If you read the testers manual a prescribed area includes the chassis and the surrounding panneling including the floor inner and outer sills and crossmembers/outriggers
(BUT) the load sensing valve as long as it is secure is NOT a prescribed area unless it is within 30 cm of another prescribed area. also a transit van is a monococh body and does not have a seperate chassis as it has no body mounts rgds Andy
http://www.motinfo.gov.uk/htdocs/index.htm
1983 mk2 2.4 swb
2006 mk6 transit recovery truck
2008 mk7 service van
maycontainnuts
