poppyabe wrote:advance diesel pump on cam vernier 1 or 2mm and jobs a good n i will start like new
If you need to do that then your pump is badly worn.
michael clohessy wrote:I have a 2.5tdi and have had a problem starting in the cold mornings, i had the glowplugs replaced last year so new they were fine. It turns out that it was a relay that was playing up, if you open your main fuse box under the bonnet and look to the top you will see two big grey relays one to the left and one to the right, the one on the left is to work the heater plugs, try replacing that. Also my heater plug light was comming on when driving and i was loosing power, i havent had that problem since.
