any common prob? mk5 blowing brake light fuse
Postby apples26 » Wed Nov 17, 2010 1:45 pm
only noticed just now my trucks got no brake lights lol, fuse blown put new one in as soon as put ign on it blows
pissing down with rain so not gonna look now, checked with the switch unplugged so its not that
if there isnt a common prob i spose ive got to climb up and check all the lights i have two lower and two higher on mine
http://WWW.NEEDATOW.CO.UK
apples26
Re: any common prob? mk5 blowing brake light fuse
Postby AlanN » Wed Nov 17, 2010 2:15 pm
Have you done any work on her lately, might have damaged a wire!
Postby apples26 » Wed Nov 17, 2010 2:18 pm
na sod all mate, just done a search and found common fault can be the wire for the fuel filter so ill check that once its stopped pissing down
apples26
Postby AlanN » Wed Nov 17, 2010 2:33 pm
:lol: :lol:
Postby Altransit » Wed Nov 17, 2010 2:43 pm
More likely a fault, or water, in the rear light cluster. Could even be a bulb blown short circuit, yes it can happen :roll: :lol:
Postby psv-hgv-flt » Wed Nov 17, 2010 7:47 pm
apples26 wrote:na sod all mate, just done a search and found common fault can be the wire for the fuel filter so ill check that once its stopped pissing down
yes check fuel filter water sensor, (wires twisted/shorting) :wink:
psv-hgv-flt
Postby slater14 » Fri Nov 19, 2010 10:29 pm
I had the same problem. Water had go in to the unit and rusted the ribbon contacts causing them to meet at the closest point.
A small screwdriver (to gently pick the rust apart) and some wet and dry (to clean up the ribbons) sorted it.
slater14
Postby apples26 » Fri Nov 19, 2010 11:08 pm
forgot to reply it was indeed the sensor on the fuel filter, plug fell down and shorted on the starter, some electrical tape was all that was needed ;)
apples26
Postby Altransit » Fri Nov 19, 2010 11:12 pm
apples26 wrote:forgot to reply it was indeed the sensor on the fuel filter, plug fell down and shorted on the starter, some electrical tape was all that was needed ;)
Oo-er, I had better sort mine out then, as its just sitting on the engine block :shock: the sensor itself disappeared some time after the garage serviced it :roll: :lol:
Postby psv-hgv-flt » Sat Nov 20, 2010 6:34 pm
8) :wink:
don't you just love it when the job don't cost ££££££££. :lol:
psv-hgv-flt
Postby apples26 » Sat Nov 20, 2010 6:55 pm
yes mate, i wont be saying that when my new truck plays up, ill allways be emptying my wallet, i sware id rather have a mk6/7 with a di in it lol
apples26
Postby psv-hgv-flt » Sat Nov 20, 2010 6:59 pm
apples26 wrote:yes mate, i wont be saying that when my new truck plays up, ill allways be emptying my wallet, i sware id rather have a mk6/7 with a di in it lol
the mk7 are worse that the mk6, but both need a lot of £££££££££££££ :roll:
psv-hgv-flt
Postby matthew2riches » Sat Nov 20, 2010 7:59 pm
My fog lights were out on my mk5....... light clusters filled about 1/3rd with water :shock: :shock: :shock: :lol:
matthew2riches
