Checking engine oil level
Postby RacinRob » Thu Dec 16, 2010 1:47 pm
Quick question about checking the oil level in my 2007 Transit 110-260.
Bought the van a few weeks back.
Checked the oil the following day, first thing on a cold engine and it was sitting about 1" above upper mark!!!!!! :roll: :shock: :roll:
Took it for a drive, let it sit for 10 minutes and its sitting at 3/4 mark.
When should I check to find the correct level, engine cold or engine hot?
RacinRob
Re: Checking engine oil level
Postby Mike » Thu Dec 16, 2010 1:50 pm
IMO hot or cold won't make a difference, just make sure you leave it an hour or so after it's run and have it on a level surface.
Mike
Wind up merchant!
Postby RacinRob » Thu Dec 16, 2010 4:32 pm
Just read the manual and it mentions to check it with engine cold - meaning I had better drain some.
Surprised the difference in levels between hot and cold though.
RacinRob
Postby Mike » Thu Dec 16, 2010 5:09 pm
The reason they say 'cold' is that you can be sure that the oil will have drained back to the sump by the time the engine is cold.
Mike
Wind up merchant!
Postby bazw » Thu Dec 16, 2010 5:43 pm
best to leave it till the engine has stood for an hour or so before testing so oil up in the head has had time to drain back into sump ( if you run engine and then stop it and dip it right away you can have a pint or so up in the head and so reading is wrong )
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
