1st Campervan
Re: 1st Campervan
Postby AndyA » Tue Dec 28, 2010 12:32 pm
The whole rear of the fridge needs venting to the outside via fridge vents. The top one also houses the exhaust.
There also needs to be drop out vents in the floor as close to the corners as you can get them.
My fridge is sealed in by adding a lip to the kitchen build for the fridge to push back against, which has the stick on foam seal. Plastic loft insulation is tucked into the bottom and packed in at the top just to make sure.
52 plate 100 MWB Hi Top Camper
AndyA
Re: 1st Campervan
Postby solarman » Fri Dec 31, 2010 3:13 am
A couple of pics with new volt meter display shbowing voltage withb engine running and heaters and lights all on...
[url]Image
Image[/url]
i am going to test all gas appliances tommorow hopefully and get all pipes and connectors ready.In the meantime i have ordered some tigerseal,split charrge relay,some 20 amp inline fuses and various other electrical connectors.The bonus is i got a locker from work today complete with lock and key just for the asking.The locker will be used as a gas locker if it fits then just needs cutting smaller,if not will be adpated as a gas and tool storage locker,so hopefully i can begin some work after new years day.Been let down by a mechanic for thbe engine side so will be speaking to someone else tommorow to service the engine,meanwhile here is a mate's travelling blog in a motorhome
http://www.funkyronster.blogspot.com/
,hope you enjoy,wish everyone a happy new year,all the best,
Solarman.
solarman
Re: 1st Campervan
Postby solarman » Fri Jan 07, 2011 9:59 pm
progress is slow as i'm waiting on other jobs being done first,but decided to remove the seating/storage on drivers side
ready for fitting appliances etc.The other side has an exact replica which i may leave in for now and adapt it as a pull out bed.I do not think this van has been insulated as i could see behind some of thbe lower plylining,but as it hasn't felt too cold and time is not on my side i will hbave to leave it for now finish it off and maybe refit it again later if thbere are any problems.
[url]Image
Image[/url]
Solarman.
solarman
Re: 1st Campervan
Postby SteveDSD » Fri Jan 07, 2011 11:03 pm
Are the barbell weights for added traction in the snow, or just ballast? :)
Good looking van.
2000 SWB 100-Campervan/Dayvan/Moneypit
Image See the van at http://www.fordtransit.org/forum/viewto ... 58&t=44950 Image
SteveDSD
Re: 1st Campervan
Postby solarman » Sat Jan 08, 2011 4:54 pm
SteveDSD wrote:Are the barbell weights for added traction in the snow, or just ballast? :)
Good looking van.
yes good guess,i threw them in when i had a bit of trouble with traction in the snow,
Solarman
solarman
Re: 1st Campervan
Postby solarman » Thu Jan 13, 2011 2:49 am
van going in on monday for engine and mot work,been advised not to do any conversion until after this so will have to wait
till i get van back before any thing can be done,
Solarman. :idea: :roll:
solarman
Re: 1st Campervan
Postby Finn71 » Mon Feb 28, 2011 2:45 am
any update on this solarman??
Finn71
Re: 1st Campervan
Postby solarman » Mon Feb 28, 2011 3:43 am
Finn71 wrote:any update on this solarman??
Hi Finn,yes i have the van back now,it failed the mot initially,main thing was welding underneath,had to bite the bullet
and spend some money(in total about £770 ish!)but i was detrmined to finish my project.I have put a fridge in,cooker,sink ,i have an oven which i need to find a position for,all these and a gas locker will be connected and tested by a
coach builder who will issue the necessary safety certification(fingers crossed again).Got some new cushions from a caravan
brekers for £70 plus some vents and cupboard doors.Unfortunately,altbbough i'm taking pics of work in progress,my pc has decided to not recognise my camera for the time being so can't upload them yet,i will update this as soon as i resolve the camera problem with some detailed comments on how i put things together,watch this space....... :D
Solarman
solarman
Re: 1st Campervan
Postby lubar45 » Tue Mar 08, 2011 5:48 pm
Hi Solarman
Where did you take it for the MOT/welding? Mine is not due till August but as Im going to a festival in August and i can see rust appearing on the bodywork Im pretty sure it will need some welding doing so want to get it done probably before.
Ps the van's looking good, keep up the good work. its gonna look like kit from knightrider soon :-)
Michael
lubar45
Re: 1st Campervan
Postby solarman » Thu Mar 10, 2011 10:20 pm
lubar45 wrote:Hi Solarman
Michael
l
Michael,i took it to a guy in Rochdale who was recommended to me by a friend,don't know where your based but i'm in Manchester,if it's close to you i can get you his number.Yes i would suggest getting all the welding work done before you actually need to use it,it's going to take up a bit of time anyway,i will also be going back to him for mechanical work(timing belt,water pump etc)as he has a good reputation and works alone.What festival are you going to and thanks for the comments,
Solarman.
solarman
Re: 1st Campervan
Postby solarman » Fri Mar 18, 2011 12:03 am
Finally i got some pics up,work been getting in the way of progress and also the gas side of things slowly
getting done.Still have a few small finishing jobs,but most things are in there now,i kept all woodwork to a
simple joint affair just wanted to get things in,so the layout is now kitchen area behind drivers seat separated from seating/sleeping area just to break it up,toilet/wardrobe at the back door.
[url]Image
[/url]
solarman
Re: 1st Campervan
Postby solarman » Fri Mar 18, 2011 12:11 am
some more pics....
[url]Image
[/url] :D
solarman
Re: 1st Campervan
Postby solarman » Fri Mar 18, 2011 2:38 am
some spooky ones,couldn't resist getting gas on the cooker and sitting in it one weekend while i planned the layout.....
there's something about gas rings in the dark that make you feel good,maybe it's a nostalgia thing from when times were good.....
[url]
Image :shock:
[/url] :shock: :shock:
solarman
Re: 1st Campervan
Postby solarman » Fri Mar 18, 2011 2:51 am
these are my leftovers which in a previous post was planning on selling,may now just put it all in the garden shbed or anothber camper conversion.....
[url]
[/url]
solarman
Re: 1st Campervan
Postby solarman » Fri Mar 18, 2011 1:08 pm
more pics....starting to get a bit cramped now with things in.....the wire cage is for the dog!
solarman
cron
