jay wrote:wonder if the little screw will line up once the drum is over the wheel studs..
Altransit wrote:Unless the wheel doesn't seat correctly in those recesses, it should be fine
Luke wrote:if your on about the drilled holes not being in the centre of the spotface then providing whatever mates to that face doesnt fould the rough casting then yes perfectly safe to use
