Bloody mondeo clocks again
Postby MarkM » Fri Sep 08, 2006 9:47 pm
Plug in speed sensor on the side of the box.
MarkM
Postby davidat19 » Fri Sep 08, 2006 10:25 pm
The same...must be a duff speedo. Put your original one in.
davidat19
Postby Guy88 » Fri Sep 08, 2006 10:29 pm
Speedo is fine its just the trip counters that dont move :?
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Sat Sep 09, 2006 12:55 am
The speedo will be duff, okay so it works but not as it should as the other 2 bits don't work.
Postby davidat19 » Sat Sep 09, 2006 6:31 pm
My fuel guage waves a bit..I don't have a handbrake light, and the side lights put the front fog light bulb on. The MAJOR problem is that the low fuel light has the arrow pointing to the wrong side! That will be confusing!
Oh, and the speedo is more accurate.
davidat19
Postby geordie white van man » Mon Sep 11, 2006 12:28 am
I bought another clock today from a P reg mk2 mondeo turbo diesel. The revs counter was reading wrong so I swapped it with the 1 from my other clock and now it all works perfect. When the fuel light comes on it does have the arrow pointing the wrong way, so you just unclip the front off the clocks and swap the black surround on the botton right hand corner which has the fuel light and a couple of other symbols on as well. The only real difference between my new and old clock is the new 1 has a resisitor board fitted to it in the middle at the bottom on the rear of the clock. The old clock didnt have that or the connections for it. Otherwise its identical to the old clocks I posted pitures of on the 1st page of this thread.
Check out our brand new community!
http://buspreservation.phpbb.net/index.php
Postby stevo » Mon Sep 11, 2006 1:03 am
Buy a Mondeo, they come with the clocks already fitted. :roll: :lol:
Formely ibanez2005
2003 100 T260 TDDi swb
stevo
Postby geordie white van man » Mon Sep 11, 2006 11:07 pm
Scratch what I said before. Just put some diesel in and the fooker is reading backwards :evil: Back to square 1 again!
Postby MrMPuk » Mon Sep 11, 2006 11:08 pm
Well if it's reading baclwards how about changing the wires round?
Postby geordie white van man » Mon Sep 11, 2006 11:13 pm
Thought of that but it was like half 9 this evening and I couldnt be arsed at that time of night
