Mysterious MPG INCREASE!
Postby RockinRick » Tue Mar 01, 2011 10:12 am
Hi Y'all-
A strange thing happened- When I fill up from empty I always reset the trip mileometer, & it usually tells me I've got about 460/70 miles left to go before fill up again, & generally does between 450/70 until I do.
This time, I filled up as usual (to the top- same as always), & the trip said I had 540 miles left- & having used most of the tank now- it seems to be on course to cover the 500 plus miles! The most it has ever done before is 470.
Can anyone explain this? Funnily, I was going to call vantuner to get it tuned for economy- can he do it by the power of thought?
I know the obvious explanation is that I've never filled it properly before & managed to get more in it somehow, but I always fill it till it clicks off, wait a bit then fill some more.Also- It cost about £95, & I have put in £99 before, so I don't see any way I can have put in 2 gallons extra.
I don't drive it hard, & cruise the motorways at 70- been driving it exactly as usual.
Don't get me wrong- I'm not knocking it- I'd just like to ensure it keeps like it!
Mk7 Jumbo 140, 148K
Any ideas?? Thanks Rick
RockinRick
Re: Mysterious MPG INCREASE!
Postby DEAN MACHINE » Tue Mar 01, 2011 11:41 am
RockinRick wrote:Hi Y'all-
Mk7 Jumbo 140, 148K
i drive the same van and ive noticed if i brim it when filling up my trip says 517 till empty but if i only fill to first click it reads 548 till empty but i still get the same out of it ,it just takes more miles before the trip moves at 517 , i can do around 40 miles before it drops to 516, but on the 548 it starts to drop after a couple of miles, im getting around 525 either way
DEAN MACHINE
Postby RockinRick » Tue Mar 01, 2011 11:47 pm
Hmmm---
I seem to be getting (Previously) about 60/70 miles a tank less than you- I'd better do something about it- unless, of course, something has cleared in the works & it's going to stay like this all the time.
I'll post what happens when I fill it again.
Rick
RockinRick
Postby angeleye » Tue Mar 01, 2011 11:50 pm
these computer estimates will go up and down with the tempreture,just use the odometer to check milage
angeleye
Postby ME » Tue Mar 01, 2011 11:58 pm
Its the Weather Cold and damp.
My 140 is the same, its doing 500/550s to a tank from empty to empty at the moment instead of the usual late 400's
Mercedes Vimto Premium
ME
Postby RockinRick » Thu Mar 03, 2011 11:34 pm
I'd respectfully like to point out it's been cold & damp for the last 6 months, & it changed about 10 days ago! I am also checking with the odometer & it seems to be doing the extra mileage- as opposed to being a figment of the computers imagination.
Is there anything that could maybe stick, then unstick, to cause this~?
Rick
RockinRick
Postby Petest » Fri Mar 04, 2011 9:59 am
Can't help with a solution / answer but I hope someone can. My 115 mk7 lwb semi high does 450 to a tank average from full and thats a mix of motorway and loacal driving. Driving like a vicar doesn't seem to alter the mileage. I don't normally carry much weight either.
I may get it chipped for economy eventually.
Petest
Postby DEAN MACHINE » Fri Mar 04, 2011 11:55 am
Petest wrote:Can't help with a solution / answer but I hope someone can. My 115 mk7 lwb semi high does 450 to a tank average from full and thats a mix of motorway and loacal driving. Driving like a vicar doesn't seem to alter the mileage. I don't normally carry much weight either.
it must be down to the axle ratio, cause mines not been chipped and i will get about 450 if i floor it , not sure what axle mine has but i have to be doing at least 50 before i put it in 6th otherwise the engine really labours , but its great for motorways which most of my job is :D
DEAN MACHINE
Postby bortaf » Sat Mar 05, 2011 12:24 am
No idea TBH but i used to get more in the tank when my Mk3 was loaded :D
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby RockinRick » Mon Mar 28, 2011 12:44 am
Quick update-
Since the first post I've now filled it maybe 6 times, & it's doing an average of 50-60 miles per tank more than it was before- for no apparent reason.
No idea why- I just hope it continues!
Cheers Rick
RockinRick
Postby Footsoldier » Mon Mar 28, 2011 5:39 am
Are the Mk7 and Mk6 fuel tank capacity the same?
Footsoldier
Postby DEAN MACHINE » Mon Mar 28, 2011 3:52 pm
yes 80 litres ,but you can get a bigger one
DEAN MACHINE
Postby Footsoldier » Mon Mar 28, 2011 7:06 pm
How big is the bigger one? Is it a custom tank or is it form Ford?
Footsoldier
Postby ake » Mon Mar 28, 2011 7:10 pm
Option from Ford, 105 litre
Postby Terry » Tue Mar 29, 2011 9:41 am
Hi
Just out of interest I checked mine, I appear to be doing 50 ish miles better per tank too.
Usually I get to about 440 miles before the low fuel light comes on. (72 litre tank)
last couple of fills its gone justover the 500 before the light came on.
I wonder if the fuel companies are feeling guilty and adding something ? ! ? ! OR
More likely taking an additive out to improve their margins now the price has topped £1.35 per litre for diesel.
On the I.O.W. last week I saw diesel at £1.49.9........... ! ! ! Yes I am sure I did a double take too.
Have fun
Terry
Pallet Puller
Terry
