thinking of changing engine and box on my ex german fire van
Re: thinking of changing engine and box on my ex german fire
Postby Vandalism » Sat Apr 02, 2011 10:41 am
i had a problem with the steering - on full lock it made a kind of knocking/creaking noise :roll:
will the problem list ever end :lol:
what electronic ignition module did u use?
Postby Luke » Sun Apr 03, 2011 8:05 pm
i'm in the same boat as you 2 guys :D (vandalism & kenb)
i'm still undecided as to what engine - either zetec or might go for the isuzu 1.7td or even the landrover 200tdi but i dont want to cut the bulkhead :) i'm the same not bothered about outright speed/power i just want something economical reliable and will pull ok :D
would be good if we all went for the same engine at the same time - stuff like making the mounts etc. it's easy enough to make 3 sets as 1 :D
only problem is the way i'm going i'll still be 1.7v4 while your both finished :lol:
Postby Vandalism » Sun Apr 03, 2011 8:12 pm
Luke wrote:only problem is the way i'm going i'll still be 1.7v4 while your both finished :lol:
i wont be doing an engine swap for a whilst anyway but still on the hunt for somthing sutable
Postby whitemice » Sun Apr 03, 2011 9:37 pm
http://www.oldcars.de/index_de.htm
FYI this lot do MK1 1.7 stuff.............at a price.
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby Luke » Sun Apr 03, 2011 9:40 pm
also these are the same engines as fitted in saab 96 (i think it's 96 :? ) mabe they can source parts :?
but thats where my engine will be going when it comes out - flogged to a saab owner who wants a mint low millage engine :D
Postby whitemice » Sun Apr 03, 2011 9:49 pm
Saab owners wave at each other!
I like those old Saab's there was a really original one would park outside mine for years until recently, i actually saw the owner and spoke with him, it was only my old physics and maths and form teacher'the bristlehound' abbreviated to 'bris' and yelled across quadrangles from pre 1975! He had the thing then too, i said i would buy it if he sells.i guess he's dead? :mrgreen:
whitemice
Postby Luke » Sun Apr 03, 2011 9:52 pm
dont buy it :!: - they have a really shite engine :lol:
Postby whitemice » Sun Apr 03, 2011 9:55 pm
I'll buy that one of yours for a couple of blueys though, this Saab was minty body wise, in grey.
whitemice
Postby Ken B » Mon Apr 04, 2011 2:10 am
Vandalism wrote:what electronic ignition module did u use?
Accuspark this time. In the past I've used the Pertronix and Loonymission. Thought I give the Accu one a go only two wires, dead simple.
Ken B
Location: Spalding lincs. The land that time has forgotton.
Postby madmark » Mon Apr 04, 2011 2:14 am
ken i have been thinking of maybe trying the acuspark kit for mine ,have you been on any trips in the van since you fitted it?
Postby Ken B » Mon Apr 04, 2011 2:21 am
Yes, I'm actually happy using now and done a few journeys with no issues whatsoever. Drives brilliantly now (apart from the stiff steering). No offence to the previous owner, but once I got it home after buying it, I was very reluctant to take it to the end of the street as it didnt run right at all I didnt think. But all new parts such as cap, rotor, leads, air filter, and plugs plus the Accu, and it runs lovely.
Ken B
Postby madmark » Mon Apr 04, 2011 2:26 am
ken have you filled the box with greese? this might help,it also sounds like somebody has messed with the adjuster screw in on the box, if this is in to far it will make the steering not return :roll: :roll: oh and the kingpins are they greesed as well?
Postby Ken B » Mon Apr 04, 2011 2:58 am
I slackened the box right off made no diffference to the stiffness. So I suspect the king pins. When it was mot'd the tester did struggle to turn the steering by hand using the road wheel even tho it was jacked up. I haven't had time to investigate that any further yet.
Ken B
Postby consul-ute » Mon Apr 04, 2011 8:52 am
i'm taking the front beam out of my 70 fire van lhd this week any good to you? i also have a stuffed v4 engine and box, rear axle all left over from my engine swap.
consul-ute
Postby Ken B » Mon Apr 04, 2011 3:26 pm
Hi, thanks, I'm hoping to go disc brake at some point so I'll pass for now. Cheers for the offer.
Ken B
Return to Mk 1 & 2
