Redcube camper damper
Re: Redcube camper damper
Postby redcube » Fri Mar 18, 2011 9:32 pm
My new bolt i found in drive way which now lives here i think the person who fixed the van before was a bit of a cow boy
striping the front down
Old belt
New belt
And i better say thanks to my mate who helped me again hes beside me treating to send the heavy's around if i didn't thank him so thank you now he must fell spacial :lol:
redcube
Postby redcube » Thu Mar 24, 2011 9:38 pm
My new floor was been laid days ago but here the pictures now it feels like a camper van
Up front i had those bit of brown wood in my shed for years and now found a use for them
At the back door
And the floor in a hole I'm relay happy with that now only cost me a €10
redcube
Postby solarman » Fri Mar 25, 2011 12:54 am
looks the part now redcube,good progress,
Solarman. :D
solarman
Postby redcube » Fri Mar 25, 2011 1:16 am
Thanks Solarman only my window to go and i have a treat in store for that lets say this window is custom
redcube
Postby FEEZ92 » Fri Mar 25, 2011 12:35 pm
She's looking fair well now sham. Well done and keep up the good work :D
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby redcube » Fri Mar 25, 2011 2:11 pm
Thanks FEEZ92 it slowing getting there and some day it will be done :)
A few day ok weeks ago i heard a bang from under the van so i deiced to look and once again a prop shaft bearing as gone :evil: same one as always and while i was under there i had a look at the handbrake which stop working too a pin at the back had gone so a bolt is now in place and it adjusted up so i have a proper working handbrake for the first time and i have had the van for nearly a year now :roll: now off to block my egr and stop the smoke :lol:
redcube
Postby FEEZ92 » Fri Mar 25, 2011 11:19 pm
redcube wrote:Thanks FEEZ92 it slowing getting there and some day it will be done :)
I fill up the centre bearings with tec7 to keep the rubber from breaking
Also you should take off the intake manifold and clean it out with a degreaser. I use Jizer and rinse it out with water or a powerhose. It makes more of a difference than blocking the EGR itself!
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby redcube » Sat Mar 26, 2011 1:02 am
Whats tec7 i was going to use expanding foam on this one as the rubber is the only thing that goes
Forgot to add i blocked my egr and the black smoke is gone but not forgotten :lol:
redcube
Postby FEEZ92 » Sat Mar 26, 2011 11:13 am
redcube wrote:Whats tec7 i was going to use expanding foam on this one as the rubber is the only thing that goes
TEC7 is like tiger seal but cheaper, about €7 per tube.
If you clean out the inlet manifold you should get all your 76 horses back, the EGR seriously clogs them up especially the banana manifold
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby redcube » Sat Mar 26, 2011 11:36 am
Ya I'm going to clean that i need all my horses just to get to the next town i live on the side of a mountain with some nice hills :lol: I'm going to get a tube of that and use it
I know why it keeps going its my springs are 190 and the vans a 100 and the prop is a mix of boat but the suspension travel stretches the prop shaft bearing and rips the rubber along the top then after a while it goes all the way around and cause the other prop shaft bearing to exploded :lol: oh the joys
redcube
Postby redcube » Sat Apr 02, 2011 7:56 pm
My van is one color again OK its red oxide
Did the breaks or lack of my pad had gone to metal to metal and i found my knocking noise to I'm missing a drop link :lol:
Now of to sort some wiring as i want to clean it all up for the inspection which should be happening in a few weeks
redcube
Postby redcube » Fri Apr 08, 2011 11:34 pm
Drop link done but a mk5 one wouldn't fit i had to get mk6 one :lol:
redcube
Postby redcube » Mon Apr 18, 2011 11:07 pm
did some odd jobs to the van over the last week most of it was painting the inside
You can see my orange camper seat covers on the roof
I got a new camera so i tried it out took a picture of the van a nice low shot
And my dash as been red for over a year now but then i ran out of paint when i started and never finished but I'm changing the color to a purple now so it will get done
redcube
Postby redcube » Sat Apr 30, 2011 11:35 am
Set of Thursday to go away for the long weekend going down the motor way the van started to whine which was followed by a very loud bang which as remind as a grinding sound pulled up to see oil dripping from under the van :( i knew the damage was done so i said I'll drive to my aunts house which wasn't far and there the van as remained the gearbox is dead the lay shaft bearing as gone and made bits of the gears the van dose move but only in first and hops out of gear but driving it isn't fun you have to listen to grinding noise and whining sounds :)
Bought a gear box out of a running mk4 with low mileages looks very clean but like all transit its red rotten :lol: i drove the van and the box seems good
redcube
Postby AK » Sat Apr 30, 2011 1:22 pm
Now thats just bad luck mate, even worse when you going away in it.
Hope you get it fixed asap
Andrew
59 plate merc splinter Luton, 56 plate 100 TDCI 350 Crew/Camper conversion
AK
