thinking of changing engine and box on my ex german fire van
Re: thinking of changing engine and box on my ex german fire
Postby Vandalism » Thu Apr 14, 2011 3:06 pm
just another question - if i change the rear exel to a 4.63 one do i need to change the prop aswell?
Postby madmark » Thu Apr 14, 2011 3:07 pm
you will have to check the flange part i think there is a erly and a late type so you need a erely axle :roll: :roll:
Postby Vandalism » Thu Apr 14, 2011 3:12 pm
you mean early like mk3 transit? or as in early like 86-89 - as oppsed to 90-92/3?
Postby madmark » Thu Apr 14, 2011 6:02 pm
the flange were the 4 bolt fitting ,i think the erly ones were difrent to the later axles, :roll:
Postby Vandalism » Thu Apr 14, 2011 6:08 pm
can anybody elaborate on this?..
Postby consul-ute » Thu Apr 14, 2011 10:24 pm
I fitted a mk2 4.63 axle in my 1970 firevan last week the prop flange mated up to the axle fine. mk2 rear shocks are a different diameter at the top
consul-ute
Postby Vandalism » Fri Apr 15, 2011 9:50 am
if i used the original shocks, this would combat the problem no?
Postby consul-ute » Sat Apr 16, 2011 11:34 pm
with the mk2 axle i used the mk2 rear shocks but sleeved the top mounts as the mk1 mounts are smaller.
consul-ute
Postby Vandalism » Sun Apr 17, 2011 10:07 am
but what if i used mk1 shocks or would they not fit on a mk2 axle?
Return to Mk 1 & 2
