Engine running with out keys in the ignition
Postby djbrowney let » Sun May 01, 2011 7:46 pm
Hi guys
New to the forum,
I want to my tranist to run with out the key in the ignition. i use an inverter to cut keys in the back but leave it running so i dont get a flat battery. Is it possible for me to do this ???
Its a 08 swb semi high 85ps btw
cheers richard
djbrowney let
Re: Engine running with out keys in the ignition
Postby the_big_fact_hunt » Sun May 01, 2011 7:56 pm
there should be a way to do it, the Police have a setup on their cars that allows them to take the keys out and leave the engine running, if you depress the clutch it stalls the engine apparently, but other than that i dont know how its done
Solve the World food problem.......... Feed the homeless to the hungry
2012 115T350
the_big_fact_hunt
Postby djbrowney let » Sun May 01, 2011 8:01 pm
Yes i know the aa and rac have vans that do it aswel but i havent a clue how they do it :lol:
djbrowney let
Postby nila » Mon May 02, 2011 9:25 am
my old van used to do it but thats becauase the ignition barrel was that worn ,then one day went to take keys out while running and the whole bloody lot came out keys/barrell :lol:
nila
Postby djbrowney let » Mon May 02, 2011 10:13 am
oh i hope that dosnt happen :lol:
There must be a simple way :roll:
djbrowney let
Postby Dagenham Dustbin » Mon May 02, 2011 5:14 pm
My van, (connect) is an ex autoglass van, and that used to do it.
I still have the switch, but its not wired up.
I was parked at the lights when another autoglass van pulled up, and he gave me a very quick demo, but his worked via the hand brake as at first it did not work, and he said, oh sh*t, handbrakes not on, so he pulled it up. switched of and removed the keys, and it was still running.
The lights changed then, so we moved of.
Dagenham Dustbin
Postby ake » Mon May 02, 2011 7:59 pm
It can easily be done with a switch, a relay, and a few fuses
Postby cyrus883 » Mon May 02, 2011 10:36 pm
all you have to do is take a switched power to the stop solinoid and when you want to run with out key :D s flick the switch and away you go :wink:
cyrus883
Postby ake » Wed May 04, 2011 7:13 am
cyrus883 wrote:all you have to do is take a switched power to the stop solinoid and when you want to run with out key :D s flick the switch and away you go :wink:
That's true up until Mk5, however doing it like that will not provide the security of the engine stalling if theclutch is pressed, or handbrake released
Postby Luke » Wed May 04, 2011 8:40 am
shouldnt be too difficult, its a basic stop/start curcuit using a relay - run the on position of the key to the start button of the relay that holds in, and put a n/c stop button under the clutch that drops the relay out - but if the key is in the stop button wont drop it out as its the equivilent of holding your finger on the start button :D
as for the starter part that would be left alone :)
i'm sure some electrical types could post up a drawing :D
Postby captain hook » Wed May 04, 2011 8:13 pm
They can be bought from any Recovery equipment dealers 8)
I have used T&C Services, Dave, for the last 20 years.. 07850 682 636
captain hook
Postby chrisr » Sun May 08, 2011 3:45 pm
Had it done to my MK5 recovery Truck y a friend of mine, It involved a few lengths of wire, A couple of fuses & some relays.
It was really good to leave it running whilst winching cars on to the truck
Where abouts are you? sure he could do it on yours
chrisr
Postby troppo » Wed May 11, 2011 4:09 am
Get a turbo timer from an old diesel truck, you can set them to run after the ignition is shut off for up to 5 minutes. A little fiddling by someone that knows electronics can cut the timer bit out easy enough. That way you have your steering lock in place as a bit of a safety thing. Doing it this way you can set it so you can kill the ignition whenever you want or leave it running.
troppo
Postby carlflvs » Thu Apr 12, 2012 8:24 pm
There is a simple system just for this, same as the emergency services use called runlock:
http://www.enginerunlock.com/
Hope this Helps :)
carlflvs
Postby 9000Parts » Mon May 14, 2012 11:25 pm
If you are anywhere neat the M1 in the Midlands then you can come and remove the Keyless Running system out of my Mk6 if you want it? Its all hooked up and functional and I have even got the User Manual (scrappy piece of A4) from the original installer with instructions on how to use it.
Basically, it will only activate with the handbrake on and as soon as you take the handbrake off it will drop the relay and stall the engine. Its only a few wires, relay and switch tucked up inside the steering cowling. With mine being installed you can see exactly which wires need to be spliced to make it work. I want it out of my van to eliminate it as a cause of some intermittent running issues ive had in the past.
9000Parts
