MrMPuk wrote:I'd put some diagonal bracing on that seat base as it wouldn't take much force to fold it in an accident.
alcapone wrote:The only reason for the original seats to have diagonals is because they use much thinner steel to keep costs and weight down.
MrMPuk wrote:alcapone wrote:The only reason for the original seats to have diagonals is because they use much thinner steel to keep costs and weight down.
Would say more down to basic engineering design.
alcapone wrote:MrMPuk wrote:alcapone wrote:The only reason for the original seats to have diagonals is because they use much thinner steel to keep costs and weight down.
Yes, but only required because they use thinner steel which alone can't take the side forces. I'll keep an eye on the welds and if there's any sign of cracking, I'll pull the base out and put diagonals in.
Brains Mk6 transit wrote:A vinyl wrap might work on the blue plastics or you could get it flocked
Luke wrote:nice work
Luke wrote:personally i think the seat base will be fine as it is (so long as the welding is good enough) the amount of force to split that would be massive - it's only holding the seat! the seat belt anchor points take all the force from your body weight - i'm building seat bases for my camper and i'm not having any diaganals
Honey monster wrote:Good job there mate, If you are ever after a proper single seat base ive got one you can have but I dont know if it would fit, Its out of an ex BT mk6 passanger side. Its just sitting in the shed since I sold my mk6. If you want ill remove the seat off it and send you the base if you just pay for the postage.
Once again, Very nice work.
Sam_I_am wrote:hmm have to disagree there, not to moan as i love this thread and really envious of the great van you started with and the better van you've created but you definitely need a diagonal brace. Based on the two pics of your welds, I wouldn't trust my life with them and for the sake of a hour or twos work wouldn't you prefer not to kill your passenger? I was always told a pretty weld is a solid weld when i trained and yours look (albeit from a bad picture) a little uneven in places. Again not trying to be rude but would definitely vote for a diagonal brace.
OK "definitely" is a little much but it would be safer..
