My MK3 cosworth
Postby Guy88 » Sat Sep 09, 2006 2:06 pm
New exhaust whent on today. sounds lovely valsheda 8) 8)
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Valsheda » Sat Sep 09, 2006 5:49 pm
Looks the bizzzzz mate and glad it sounds great :P 8) :D
Valsheda
Top Tourneo Owner
Postby 100ps_drw_hicube » Sat Sep 09, 2006 6:03 pm
8) 8) 8) 8) 8) nice one guy 8) 8) 8)
100ps_drw_hicube
Transit Abuser!!
Postby rover » Sat Sep 09, 2006 7:42 pm
Luvly jubbly mate :D
Just need to get the dents out of the bumper now, or is that what the exhaust is for? To take the emphasis off the bumper :wink:
Rover.
rover
Postby Guy88 » Wed Sep 20, 2006 10:25 pm
Nothing much happend latley. been bust getting the 24v ready.
Once this is in i will also fit the Air con as its all on the same loom (well sort of :P )
then i will be back onto the paint :(
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Sat Sep 23, 2006 7:38 pm
24v out of car today, loom out tomorrow :P
Just need an adaptor plate and flywheel now :(
Decided to make up a frame to hold it all solid so i can try working out the wires and then transfer it into the van. May even start it befor i fit it
Heres what i got now
incase i forget the auto box is where it should be
In the boot :lol: :lol: :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sat Sep 23, 2006 7:40 pm
Guy88 wrote:Decided to make up a frame to hold it all solid so i can try working out the wires and then transfer it into the van. May even start it befor i fit it
why not use the granny crossmember :?:
Postby Guy88 » Sat Sep 23, 2006 7:42 pm
I started one for college to hold a pinto test rig.
just need to adapt it for the V6
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby rover » Sun Sep 24, 2006 12:54 pm
From what I can gather from the Capri forum you should be able to use the flywheel and clutch from a 2.8i and the MT75 box will fit straight on (with the adapter plate of course).
Rover.
rover
Postby Guy88 » Sun Sep 24, 2006 8:49 pm
loom out today. worked out the wires.
From what i worked out I think i have to connect 1 ign live, 3 perminant lives, 5 earths.
This is by using the splices in the granny loom :wink:
And this is what it looks like
And the poor granny
and Big John. the little valve in the vaccuum pipe that was with the loom is the cannister purge valve. F**K knows what it does :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby ovlov » Sun Sep 24, 2006 10:43 pm
Guy88 wrote:
Is that a little dog or are they just very big boots :lol: :lol:
I want to live forever so far so good
ovlov
Postby Guy88 » Sun Sep 24, 2006 10:49 pm
he's only little. at least its not a cat. means theres no jokes about removing it :lol: :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby madmark » Mon Sep 25, 2006 2:08 am
:) good luck mate you must keep us all upto date on this conversion ,i would think a 2.8 or 2.9 flywheel would fit the crank! you have your old box out so you can mess about by putting it together and see! :wink:
Postby Guy88 » Mon Sep 25, 2006 6:05 pm
I am going to use a 2.8 as its half the weight of the 2.9 :wink:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon Sep 25, 2006 6:09 pm
Guy88 wrote:the little valve in the vaccuum pipe that was with the loom is the cannister purge valve. F**K knows what it does :?
is that for the charcole canister :?: there was one on my rover engine :lol:
