AOK
AOK
Postby DKR1966 » Thu May 19, 2011 5:49 pm
The plan was MOT and sell, had the van for 2 years now and thought it was time i upgraded to a newer model. BUT having never let me down except for a ball joint popping against what i might come up against with a MK6 i've decided to keep it!
Put new springs ball joints and track rod ends on the front end, a complete new exhuast. New handbrake cable and new brake shoes.
Changed oil, air filter, fuel filter and blanked off the egr and removed butterfly.
Now it is looking a little scabby round the front wings so I thoght a little exploration is in order, so i dropped the front bumper off to get a better look at the front end and found
This
And this
I think thier should be some metal in ront of the washer bottle, so i rang local ford dealer. How much for an inner wing, £105 they say! It will get fabricated when i replace the wings over the coming weeks.
Also plan is to replace rear doors with a better pair
So the plan is to fit four wings, two archs with sill extensions and repair the inner sill below the sliding door.
Then a change of colour from the horrible btgrey to matt black as i love mattblackminibus's van.
Will keep you updated
Dave
DKR1966
Re: AOK
Postby transitandy » Thu May 19, 2011 6:35 pm
what you got planned sounds nice m8y :)
Re: AOK
Postby nila » Thu May 19, 2011 7:01 pm
that second picture looked like mine when i went poking about and when took wing off the whole inner arch had gone :( .
but managed to sort out inner wing with the decent metal left on wing so all good now :D .
hope you get it sorted and mattblack is a sweet colour ,good luck and keep us posted :D :D
nila
Re: AOK
Postby DKR1966 » Fri May 20, 2011 1:00 pm
First coat on the bonnet
DKR1966
Re: AOK
Postby DKR1966 » Sun May 29, 2011 6:35 pm
Found a very tidy pair of doors on fleebay for 30 nicker, no rot just the odd little ding here and there.
Ordered some lightguards, clear indicators and clear repeaters.
DKR1966
Re: AOK
Postby DKR1966 » Mon May 30, 2011 1:07 pm
Not so smiley now! MK4 grill fitted.
Cant really do owt else with this piggin rain!!!!!!
DKR1966
Re: AOK
Postby blue estate » Mon May 30, 2011 1:30 pm
It's lovely and dry down here on the south coast :lol:
MGS5 and MG5
VOLVO FH daily drive
blue estate
Re: AOK
Postby DKR1966 » Mon May 30, 2011 8:11 pm
Well the sun came out, so i made a start on repairng this weeks f**k up where i dint notice the wall behind me
had to try knock it out from the inside and a bit of filler, this will be the third rear lense ive bouhgt in the last two years.
Picked these up ready to clean up and get redilled 7j x 16 wellers
DKR1966
Re: AOK
Postby noah » Wed Jun 01, 2011 1:24 pm
good work
noah
Re: AOK
Postby DKR1966 » Wed Jun 01, 2011 1:29 pm
noah wrote:good work
DKR1966
Re: AOK
Postby DKR1966 » Thu Jun 02, 2011 12:34 pm
Light guards turned up today
Also genuine parts full mk6 rear bumper, pictures to follow when i have figured out how to get it to fit
DKR1966
Re: AOK
Postby nila » Fri Jun 03, 2011 7:52 am
looking good so far i like it :D
nila
Re: AOK
Postby mr2swzo » Fri Jun 03, 2011 4:37 pm
Why make a mk5 look like a mk4?
This van would look ace if you put the mk5 grill back on. Replaced the rotten metal and sprayed it white. You could make it look like it left the factory?
mr2swzo
Re: AOK
Postby DKR1966 » Fri Jun 03, 2011 5:48 pm
Trouble is it left the factory BT grey which is a horrendous colour. MK 4 grill as a MK 6 bumper going on. Can't afford resprays in nice factory colours at the end of the day it's a work van loaded to the gills with all my tackle and the amount ot times I catch walls and gateposts I would be in tears if I made it mint. The budget was/is £500 to make it look half decent with a bit of individuality. I've kept all original parts so at a later date someone else can return it to it's former glory.
DKR1966
Re: AOK
Postby DKR1966 » Fri Jun 03, 2011 5:52 pm
Jurys out on this one, not sure if i do actually prefer MK5 bumper. Maybe if i can make up some trim that sits below door and above bumper it might look better.
And one of the dash with working cup holder
DKR1966
