V6 Conversion Parts Checklist - Help Required
Re: V6 Conversion Parts Checklist - Help Required
Postby bagss2 » Wed Jun 08, 2011 6:48 pm
Luke wrote: its the transit manual MT75 what causes the problem :(
This is what I understood... And feared! :?
Does anyone have a proven solution?
What do the 2.9 (12v or 24v) boys do??
Thanks for your feedback by the way, much appreciated! :)
bagss2
Postby Luke » Wed Jun 08, 2011 7:27 pm
well with my 24v i made 2 stainless manifolds that went round it but other ideas are making spacer blocks to move the standard granada manifolds out :D
if i was you i'd get some 2nd hand tubilar ones and either bend them or cut and weld in a couple of tubes either side :idea: :D
Postby rob hall » Wed Jun 08, 2011 7:59 pm
Just do what I did! Cheap and cheerfull ! Check in customing,under cosworth boa,
the welsh A-team!
rob hall
Postby bagss2 » Thu Jun 09, 2011 12:10 am
Luke wrote:if i was you i'd get some 2nd hand tubilar ones and either bend them or cut and weld in a couple of tubes either side :idea: :D
rob hall wrote:Just do what I did! Cheap and cheerfull ! Check in customing,under cosworth boa,
Thanks guys - both top ideas. :D
It won't be me doing the cutting / welding / customising (due to complete lack of talent :lol:) - so the decision which way to go will probably be down to my skilled pal(s)...
Would appear that these are the two practical options though - thanks again! :D
bagss2
Postby AlanN » Fri Jun 10, 2011 12:54 am
Modified tubulars are the way to go I recon, Fordboynick and Browny both have type 9 boxes, well Nick did until it got stolen :( so no probs with the clearance
Postby MinorMatt » Sun Jun 12, 2011 2:22 pm
Well I have made one manifold for the 2.9 and the next one will be made soon...
Postby bagss2 » Sun Jun 12, 2011 11:26 pm
MinorMatt wrote:Well I have made one manifold for the 2.9 and the next one will be made soon...
Don't suppose anyone has a set of old manifolds/downpipes that they 'knocked up' for a 2.8 and then subsequently upgraded?? :D
Long shot, I know... but, if you don't ask........
Cheers, Baggers.
bagss2
Postby AlanN » Sun Jun 12, 2011 11:28 pm
Mmmm! yes, its a long shot :!: :wink:
Postby bagss2 » Wed Jun 15, 2011 11:40 pm
Well, I've managed to source a set of Janspeed tubular manifolds for a 2.8 Sierra - locally off a pal of a pal... :)
Although they'll be cheap enough, does anyone know if they'll do the job as well as Capri ones? :?: It was Capri ones I read somewhere...
Cheers, Baggers.
bagss2
Postby MinorMatt » Fri Jun 17, 2011 11:11 am
Fit em and find out!
Postby AlanN » Sat Jun 18, 2011 1:12 pm
I still think your going to have to mod them and I dont think they are any different to Cappa ones
Postby fordboynick » Sat Jun 25, 2011 11:08 pm
Can you take some pics of you new down pipes so we can see if they will go on :)
Transit Customising and Restoration
All types of customising bodywork & welding undertaken in our fully equipt workshop. Big engine transplants
fordboynick
Registered Trader
Registered Trader
