BROWNYS V6 MK3
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Tue May 17, 2011 8:27 pm
yea was good to meet up 8) ur van sounds sweet al :wink:
BROWNYS V6
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Tue Jul 05, 2011 6:40 pm
bit of an update, went out in van on sunday and brakes were makin a weird noise, so had a quick looky last nite :x
im now off outside to fit a new rear wheel cylinder, and a set of front pads :roll:
im gonna look into fitting discs on the back i think :wink: an stiil on the lookout for some vented front calipers to go with my new discs for the front :?
BROWNYS V6
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Tue Oct 11, 2011 8:03 pm
do i need to change my name :P
but then it all went a bit pete tong :(
so its got this old smoker in it at the mo :roll:
BROWNYS V6
Re: BROWNYS V6 MK3
Postby transitandy » Tue Oct 11, 2011 8:17 pm
welcome back m8 :wink:
Re: BROWNYS V6 MK3
Postby MinorMatt » Tue Oct 11, 2011 8:49 pm
why is it pink? :shock:
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Tue Oct 11, 2011 9:58 pm
transitandy wrote:welcome back m8 :wink:
ta mate :)
MinorMatt wrote:why is it pink? :shock:
block is pourus, filled it with coolant(pink)and it ended up in the cylinder/sump :evil:
so i got to build another 'new pinto' :roll: :lol:
BROWNYS V6
Re: BROWNYS V6 MK3
Postby AlanN » Wed Oct 12, 2011 8:11 am
Looks like youve put a ton of effort into that lump too :(
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Wed Oct 26, 2011 8:29 pm
AlanN wrote:Looks like youve put a ton of effort into that lump too :(
yea too much effort :( never mind, although its got an old pinto in it, i did leave my straight cut quaife gearbox in there :shock: but ive only driven it 3 times and i took it back out tonite an put a standard 5 speeder back in cos its to fookin noisey :lol:
i can pull away without slippin the clutch now :wink: an im gonna put a mk2 clutch pedal in there so i can do away with the ratchet thing :x
BROWNYS V6
Re: BROWNYS V6 MK3
Postby G40GES » Wed Oct 26, 2011 8:35 pm
When you decide to 'chuck' the ol smoker away, chuck it this way :wink:
Change ya name?
how about Mr 'Pink'
(sorry had to be said :roll: )
Gadge in the shed... STILLfreezing me bits off...
G40GES
Re: BROWNYS V6 MK3
Postby AlanN » Wed Oct 26, 2011 8:35 pm
Looks like you should be rebuilding 2 V6's over the winter then :wink:
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Wed Oct 26, 2011 9:02 pm
G40GES wrote:When you decide to 'chuck' the ol smoker away, chuck it this way :wink:
sorry gadge the ol smoker is a family heirloom :lol: wont be chuckin it anywhere :wink:
AlanN wrote:Looks like you should be rebuilding 2 V6's over the winter then :wink:
got 2 v8's awell :wink:
BROWNYS V6
Re: BROWNYS V6 MK3
Postby G40GES » Wed Oct 26, 2011 10:15 pm
I did clock you @Porkys earlyer in the year... Bad boyed swb with some nice little touches! was a blue top cologne :?: the only Van night so far (but i did manage to get down to Robbie Cees birthday bash WOY OYH bbbrrrrrrutt!) i didnt get the pleasure of witnessing your little beasttaking of up the road as i had to bust a move early (Essex classics night? 2 nice cortiners mk2s :? ) but if it worked like your 'heirloom' looks then maybe a little chinwag over a suitable new home to put it?... heirlooms are precious things im aware... and how many engines and boxes!? :P 8) :mrgreen:
this little YB has been keeping us busy, not mine but its been fun... nearly as much fun as transits in the wet :lol:
G40GES
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Thu Oct 27, 2011 8:05 pm
tidy ol thing gadge 8) bit to modern for me though :wink:
BROWNYS V6
Re: BROWNYS V6 MK3
Postby transitandy » Sat Oct 29, 2011 5:52 pm
does look 8) :)
Re: BROWNYS V6 MK3
Postby BROWNYS V6 » Sat Dec 03, 2011 8:11 pm
bit of an update, since swoppin to pinto power the clutch has been sh*t£, so pulled it to bits a couple of nites back, and modded a mk2 pedal so i dont have that poxy ratchet anymore.
bit more involved than i first thought, but i think its sorted, goin for a road test tomoz, as i could'nt be arsed tonite :lol:
just got some coil wiring to tidy up, then maybe i will risk taking it to the ace on wednesday eve :)
BROWNYS V6
