Lowered my connect.
Re: Lowered my connect.
Postby connect_4 » Sun Nov 06, 2011 9:48 pm
I just got hold of some RS springs, just got to get cups and bearings now.
cheers
Andy
connect_4
Postby valetech » Sun Nov 06, 2011 9:50 pm
I just got some 60mm lowering springs for a standard focus.
molested by:
19s is how we roll
valetech
Postby GKandR4CH » Mon Nov 07, 2011 12:39 am
And where are mine???? :evil:
Read the forum rules
GKandR4CH
Postby connect_4 » Sat Nov 12, 2011 2:29 pm
So i now have the front RS springs, are these the top mounts / bearing i need ?
http://www.ebay.co.uk/itm/170575017074? ... 2813wt_989
top cups from the breakers yard.
cheers
Andy
connect_4
Postby van mann » Mon Nov 14, 2011 12:04 am
connect_4 wrote:So i now have the front RS springs, are these the top mounts / bearing i need ?
cheers
Andy
Yes they will do ,but you still need the spring cup(in the pic above below the spring).
van mann
Postby valetech » Mon Nov 14, 2011 9:34 am
cheers
Andy
are you mad?
most breakers yard would not just sell you the top cup,they will make you buy a whole leg.saying that it will be cheaper to do any way as that item on the bay is £15.00 each.
you can buy a whole leg for around that
molested by:
19s is how we roll
valetech
Postby connect_4 » Mon Nov 14, 2011 10:01 am
I will make some calls to the breakers yards and see what they charge for a complete leg, cheers.
Andy
connect_4
Postby connect_4 » Mon Nov 14, 2011 2:32 pm
you are right, just bought 2 legs for £10 each =- thanks for the info.
so i've got everything now to lower the front.
A pal of mine is welding the plates on the rear axle so i can lower the rear.
So when i get the van back from the bodyshop next week (Performance Blue colour change) then i'll sort out the lowering, pics will follow.
cheers
Andy.
connect_4
Postby Honey monster » Fri Nov 18, 2011 4:08 pm
Just been looking under the back of the van, If you lower the back by putting the axle on top of the springs do you need to make any alterations to the load sensing valve bracket on the axle?
Honey monster
Postby valetech » Fri Nov 18, 2011 4:12 pm
Yes
molested by:
19s is how we roll
valetech
Postby connect_4 » Fri Nov 18, 2011 5:30 pm
valetech wrote:Yes
In what way, what sort of modification do you have to do ?
EDIT :
4.After lowering it you need to adjust the brake load compensater to the end PIC 2 as the valve thinks the van is fully loaded and the brakes become quite sharp.If you have ABS Ignore this.
connect_4
Postby belly » Fri Nov 18, 2011 7:25 pm
On my old froggy hot hatches i'd mark the load sensing valve first then adjust it back to that mark once i'd lowered it :D
belly
Kaiser Chief
Postby connect_4 » Sun Nov 20, 2011 2:10 pm
Can anyone tell me what the distance is between the original mount point and the middle position ?
thanks
Andy
connect_4
Postby GKandR4CH » Sun Nov 20, 2011 6:08 pm
PM Vann Man he is bound to know.
GKandR4CH
Postby connect_4 » Sun Nov 20, 2011 6:11 pm
GKandR4CH wrote:PM Vann Man he is bound to know.
i've done that - thanks.
connect_4
cron
