Parts needed to finish it off!
Re: Parts needed to finish it off!
Postby mealic » Sun Nov 20, 2011 8:10 pm
Vandalism wrote:you dont mind it will be on the sunday do you? or did you need the wheels earlier?
We could clean them up and spray primer them and you could do the nice job on the sunday and get all the praise with the final coats,if you like :) :)
`04 2.3 petrol/LPG
mealic
Postby Vandalism » Sun Nov 20, 2011 8:18 pm
yes that could work..make things go along a lot faster 8)
Postby mealic » Sun Nov 20, 2011 8:26 pm
Shall we use rattle cans then or anyone got a couple of primer used guns.Will the white be the same as the paint we already have/had??
`04 2.3 petrol/LPG
mealic
Postby Luke » Sun Nov 20, 2011 8:27 pm
how many cans do you think we'll need to do the wheels :?:
Postby Vandalism » Sun Nov 20, 2011 8:32 pm
i wouldnt go as far as saying 1 can per wheel but id say about half a can per wheel maby so thats 3 cans...mabey 4 to be on the safe side
Postby mealic » Sun Nov 20, 2011 8:32 pm
Some Red primer.One primer,one topcoat for each wheel??Ideally one laquer for each wheel.
Expensive!!
`04 2.3 petrol/LPG
mealic
Postby Luke » Sun Nov 20, 2011 8:33 pm
i think we should still have some of the van paint left over :idea:
Postby Vandalism » Sun Nov 20, 2011 8:34 pm
i wouldnt use red it might show through the white a bit..id use grey primer
what form is the paint in from the van...can/tin/for compressor use?
Postby mealic » Sun Nov 20, 2011 8:42 pm
Red for anti_rust. Or whatever you think.
`04 2.3 petrol/LPG
mealic
Postby Vandalism » Sun Nov 20, 2011 8:48 pm
from prevous experience, red primer needs more top coat to stop it showing through it you know what i mean but its up to you, what ever you have will work fine :)
Postby dieselhead123 » Tue Nov 22, 2011 4:30 pm
I will put this all over the forum until we solve the problem!
We need a pair of front spring hangers for the makeover van, all the suppliers that I have access to are showing no stock with no anticipated delivery date :!:
We need these parts.
If any of you have any suppliers you know of that might have these parts, we need two, in stock please contact them as there appears to be a global shortage :!:
The front spring hangers are NOT handed, ie. left/right and are the same on Mk3, Mk4 and Mk5 models.
If anyone locates any, please pm Luke or myself
Thanks lads
Postby dieselhead123 » Tue Nov 22, 2011 6:33 pm
Postby Vandalism » Tue Nov 22, 2011 6:45 pm
:mrgreen: :lol: :roll:
Postby Luke » Tue Nov 22, 2011 7:24 pm
problem is the delivery dates :? - ive rung up the 2nd one to see if we buy them we can have them delivered before this weekend but i didnt get through so i left a message on the answerphone :)
if anyone on the fourm has any that we could get to the build then we can order some off ebay to be delivered to replace the one/ones donated :idea:
