Wood Burners...
Re: Wood Burners...
Postby winterheating » Sun Nov 27, 2011 8:30 pm
SteveDSD wrote:
harryvanman wrote:dont understand a word of that, just know there 's not any damp in my van and there was when i had a gas fire in it,also nothing else has been changed
He's saying burning wood, or pretty much anything, gives off water vapour. The reason you don't seem to get as much condensation with a wood burning stove is probably because of the 'draft' taking the smoke and water vapour up the chimney. Ventilation does make a big difference.
Yep that's right things like portable gas heaters, or ovens, hobs basically anything flueness will cause a lot of water vapour in the air, or a poorly flued/ventilated open appliance as you say.
With any fuel.
winterheating
Re: Wood Burners...
Postby sc_BK » Mon Nov 28, 2011 12:35 am
When you burn wood, the water in the wood is released, it's all goes up the chimney, but when it cools it can come back down
Oh by the way you're not really supposed to use anthing over a 45deg bend in the flue
sc_BK
Re: Wood Burners...
Postby screechowl » Tue Dec 06, 2011 11:40 pm
mutus wrote:I made one out of a gas bottle for use outside the van boil a pan of water on the top,but got thinking how i could use it inside as well,so i got 4 pieces of galvernised steel which stand round the stove, smoke goes up a flue pipe wiyh a 90 degree bend on then another 90 degree bend and then out of a side window.i only use it when parked up as it all dismantles brilliant i also have a recliner armchair in the van ,real comfort if i could figure out how to put photos on i would.
cheers Eddie
Figure it out please :D :D :D
screechowl
Re: Wood Burners...
Postby screechowl » Tue Dec 06, 2011 11:47 pm
ursus wrote:
vana mana wrote:
ursus wrote:I used to have a woodburner in a couple of caravans I used to own.They took up a bit of space and could get very warm,but when it's minus 10 outside,I was sure nice and toasty :D :D also machine mart woodburners are rated value for money amongst a few hippy travellers I know.
Get orf my land..lol..u go on Tribal Living ?
I browse Tribal now and again :)
Me too :D
screechowl
Re: Wood Burners...
Postby screechowl » Tue Dec 06, 2011 11:49 pm
waveyr02 wrote:I made a small woodburner out of a pub gas bottle and a scaffold pipe for a chimney it is fitted in a swb standard size van there is a picture of it somewhere on the forum under swb day van. It has been fantastic and i have been working away for the last two weeks staying in the van i dont think i would have managed without it.Cheers Simon.
I have to see the pics, please...
screechowl
Re: Wood Burners...
Postby waveyr02 » Thu Dec 08, 2011 9:22 am
Here is a picture of the stove,i have since re arranged the interior but stove still in place. Simon.Image
waveyr02
Re: Wood Burners...
Postby screechowl » Thu Dec 08, 2011 12:14 pm
Beautiful :)
screechowl
Re: Wood Burners...
Postby winterheating » Thu Dec 08, 2011 12:35 pm
Does look good.
You could get some hot pole dancers on that.
winterheating
Re: Wood Burners...
Postby transitandy » Thu Dec 15, 2011 12:29 am
winterheating wrote:Does look good.
x2 :)
Re: Wood Burners...
Postby ursus » Thu Dec 15, 2011 2:30 pm
waveyr02 wrote:Here is a picture of the stove,i have since re arranged the interior but stove still in place. Simon.Image
am sure you could sell a few on here or Tribal Living.
ursus
Re: Wood Burners...
Postby ursus » Fri Dec 16, 2011 10:41 am
harryvanman wrote:got a woodburner in my transit luton,also had one in a lwb tranny.www.thefireweaver and this one from him gives free electrickery, 12v 20 watts. so heat and power for a few scraps of wood.A burner gives you dry heat,unlike a gas fire,so helps stop condensation.sit in armchair,next to fire,side door open and fishing rod out and a brew on stove.
That Tinderbox sure looks the dogs! very nice indeed and I wouldn't need candles for light any more :D
ursus
Re: Wood Burners...
Postby G40GES » Sun Dec 18, 2011 11:44 pm
ive found some nice boiler plate at work and wonder if i could make a water jacket for a water heater system... i'm not savy on boiler systems so may well BLOW the whole thing up :shock: :? :idea: i'll do a search
Gadge in the shed... STILLfreezing me bits off...
G40GES
Re: Wood Burners...
Postby screechowl » Thu May 31, 2012 8:15 pm
chris2790 wrote:
(ps - ignore the scuzzy hippy comments, and let them be cold... but still upstanding members of society :wink: )
8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
screechowl
cron
