Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby robbie.cee » Wed Dec 14, 2011 11:47 pm
Getting there m8 !
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby G40GES » Mon Dec 19, 2011 12:07 am
what happend to the fillter element?
looks like Dawn Machenzze has just had a turn :shock: or something has been breathing easily :lol: :shock: pinto power?
Gadge in the shed... STILLfreezing me bits off...
G40GES
Postby robbie.cee » Mon Dec 19, 2011 9:16 pm
m8 must have been proper fkin clogged. must have been slowing me down!
pinto sorted, my neighbour ade tweaked the distributer timing and she perked right up!
got a Di centre box, brand new from s e motor factors, £28 inc vat (&2 gaskets)
will fit weds as off weds, should be within my abilities(i hope lol)
should be less dragster sounding then :lol:
Had
MAKE IT FIT
robbie.cee
Postby MattBlackMinibus » Mon Dec 19, 2011 9:34 pm
robbie.cee wrote:pinto sorted, my neighbour ade tweaked the distributer timing and she perked right up!:
8) 8) Nice one. Racey cam next then? Big valve head ? :twisted: Get saving :twisted:
Starting All Over Again
MattBlackMinibus
Postby robbie.cee » Mon Dec 19, 2011 10:10 pm
Yeah was thinking cam. is it JUST the cam, or do you have to change followers etc too??
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Tue Dec 20, 2011 7:47 pm
Well i got home early ish today so i had the opportunity to use the last of the daylight to get under the van and sort the exhaust.
fitted a standard Di centre box, on its own it sounded wicked,
got my stainless cut down to length and fitted, sounds ok but really quiet. Oh well least i wont draw too much attention ! :lol:
Had
MAKE IT FIT
robbie.cee
Postby MattBlackMinibus » Tue Dec 20, 2011 10:08 pm
robbie.cee wrote: Oh well least i wont draw too much attention ! :lol:
Handy in Essex I would imagine, let them pull over the saxos instead!
As for the cam, I think it's just buy and bolt in, but someone will let you know.
MattBlackMinibus
Postby robbie.cee » Wed Dec 21, 2011 12:22 am
it defo running better but still think it needs some magic touch as theres not much past 4000 rpm, or is this normal for a 30 yr old pinto lol?
reckon its holding back a tad but such a quiet delight to drive theres fek all engine noise now!!!
Had
MAKE IT FIT
robbie.cee
Postby transitandy » Wed Dec 21, 2011 2:54 pm
put a twin carb on it :) and yes they are are lovely and quiet indeed :lol: :)
Postby robbie.cee » Sat Dec 24, 2011 12:47 am
possibly vacuum advance wasnt connected , on account of pipe being too long and worn end so cut it off, reattached it. made some mid range improvement but think dizzy needs readjusting now said pipe firmly reattached!
toying with a twin 40/45 tho if ANYONES SELLING ONE CHEAP :wink: :wink: nudge nudge
Had
MAKE IT FIT
robbie.cee
Postby transitandy » Mon Dec 26, 2011 2:02 am
robbie.cee wrote:toying with a twin 40/45 tho if ANYONES SELLING ONE CHEAP :wink: :wink: nudge nudge
Them fookers go for a fortune on the bay :roll: goodluck in gettin some :wink: although they would make one hell of an improvement 8)
Postby robbie.cee » Tue Dec 27, 2011 7:26 pm
Had a play with the dizzy today, think im getting the hang of this trial n error lark. Also re instated the PATS today as i got the RIM module back from Dieselhead123 that was on my diesel engine. plugged it in, replaced the relay and no more flashy flashy moany moany PATS. all good. just gotta wire fuel shut off thru pats module now(via relay) to give me few more mins if someone tries hotwiring from inside!!
That said i want a quick release steering wheel like AndyJ's got !!! 8)
Some more piccies but apologies for quality as was taken on my phone ...
Had
MAKE IT FIT
robbie.cee
Postby Luke » Tue Dec 27, 2011 8:09 pm
haven't you got a set of wellers for this robbie :?: :D
Postby AlanN » Tue Dec 27, 2011 8:24 pm
Yes he has Luke, you pilot drilled them for him, I reckon his keeping them for a surprise for us :lol:
Postby robbie.cee » Tue Dec 27, 2011 8:34 pm
AlanN wrote:Yes he has Luke, you pilot drilled them for him, I reckon his keeping them for a surprise for us :lol:
yes they are in shed- can drill out t5he 13mm holes, but i neede a 60degree metal counter sinker. think ill ask captain hook nicely if he'll get his man with a metal shop to finish the holes!
Had
MAKE IT FIT
robbie.cee
