Radio Codes
Re: could somebody help me with a radio code please
Postby APH » Wed Jan 04, 2012 12:34 am
Try 7006
Andy
APH
Re: Radio Codes
Postby tunster » Fri Jan 06, 2012 2:15 pm
mk6 radio code required. m050801 please.
tunster
Re: Radio Codes
Postby cos transit mk3 » Fri Jan 06, 2012 2:44 pm
[quote="tunster"]mk6 radio code required. m050801 please.[/quote]
3429
cos transit mk3
Re: Radio Codes
Postby tunster » Sat Jan 07, 2012 6:34 pm
tried that cos but it didnt work. Any ideas? I could wipp the radio out tomorrow if needed?
tunster
Re: Radio Codes
Postby cos transit mk3 » Sat Jan 07, 2012 6:59 pm
[quote="tunster"]tried that cos but it didnt work. Any ideas? I could wipp the radio out tomorrow if needed?[/quote]
that what the software comes up with mate :(
cos transit mk3
Re: Radio Codes
Postby tunster » Sat Jan 07, 2012 7:13 pm
Hmmm? when i entered it then pressed 5 it just went back to code? Am i doing it right? Will go and look back at the beginning of the thread.
tunster
Re: Radio Codes
Postby Highlander250469 » Sat Jan 07, 2012 11:54 pm
[quote="cos transit mk3"]no problem and to anyone else who needs code you only have to hold 1&6 for a few seconds then serial number will show on screen much easier than removing unit!![/quote]
I've tried that today with six different radios but couldnt get it to display the serial number, it does display some dates or version numbers I think but no serial no.
The ones I tried were in Scorpios, from1995-98 models, fitted with RDS 5000, 6000, 7000 and a VNR9000 sat nav unit.
Is it maybe newer version radios it works with?
Highlander250469
Re: Radio Codes
Postby Highlander250469 » Sat Jan 07, 2012 11:57 pm
double check your serial number.
It has possibly been reprogrammed and has a different code now though, in which case you may need it doing again.
Highlander250469
Re: Radio Codes
Postby tunster » Sun Jan 08, 2012 12:25 pm
ok highlander i will double check. When i held in 1 and 6 it showed some other data[i will note this time what it says] and will post it up shortly.
tunster
Re: Radio Codes
Postby tunster » Sun Jan 08, 2012 2:36 pm
problem now sorted. Took out the radio and hey ho some good chap wrote the code on top. I got wrong serial number it was actually m014027 code 3803. I dont know what the other stuff was when holding in 1 and 6 though. This is what came up.mgp dj5,then 4-06 with a number 1 over the number 3 channel button,then 050801 and cd again above number 3 channel button. Anyone know what thats all about????
tunster
Re: Radio Codes
Postby Highlander250469 » Sun Jan 08, 2012 5:51 pm
same as what mine all showed, nothing that looked like the serial number though
Highlander250469
Re: Radio Codes
Postby robincaz » Tue Jan 10, 2012 12:12 pm
Hi
Radio code needed please for my Mk5 smiley.
The serial number is M030388
Thanks muchly. :-)
Caroline
robincaz
Re: Radio Codes
Postby cos transit mk3 » Tue Jan 10, 2012 1:13 pm
2211 mate
cos transit mk3
Re: Radio Codes
Postby robincaz » Tue Jan 10, 2012 3:56 pm
Cheers, they worked. :-)
robincaz
Radio Code
Postby PatrickMulla » Mon Jan 16, 2012 7:15 pm
Hi,
Would anyone know the code for a radio with the following serial number:
M347532
Cheers in advance,
Patrick.
PatrickMulla
