two stroke oil in the diesel ?
Re: two stroke oil in the diesel ?
Postby ihaveagsxr » Thu Oct 08, 2009 11:28 pm
so yey or ney on mk7s
ihaveagsxr
Postby winterheating » Thu Oct 08, 2009 11:31 pm
yeah, and if it breaks down the partical filter just smash it out. problem solved.
the oil must help with lubrication, as modern diesel pumps reley on purpose made coatings which the oil will only help.
winterheating
Postby FATBOYFIN » Fri Oct 09, 2009 7:33 pm
Glad you agreed with me in the end :D
FATBOYFIN
Postby pikeybob » Sat Oct 10, 2009 11:58 am
Hmn :? Anyone tried a mk7 on it :?: Fancy giving it a whirl as lube is good but dont wanna FUBAR anything
The only mk7 still with ORIGINAL egr valve!!!!!!
pikeybob
Postby ihaveagsxr » Sun Oct 11, 2009 8:17 pm
well iv used it in 2 tanks a wile back and the last 950 miles too. i think i might be getting more milage out of it. will know later in the month as iv recorded all the diesel iv put in and im going to see my average over a thousand or so miles
ihaveagsxr
Postby pikeybob » Sun Jan 10, 2010 12:18 pm
Wheres the partical filter ???
pikeybob
Postby happyshopper » Sun Jan 10, 2010 1:29 pm
Holy thread resurection batman! :shock:
happyshopper
Postby pikeybob » Sun Jan 10, 2010 1:38 pm
hell yeah im bored
pikeybob
Postby toniel » Tue Feb 02, 2010 1:43 pm
Hello all.
I have now sold my beloved tranny but have been meaning to post my last 2 stroke results here for yonks. To replace the tranny, I now have a Berlingo camper turbo diesel and I am considering adding 2 stroke to that which is what brought me back to this forum.
Like some others I found that I was getting a 2.5 mpg improvement, even allowing for the quantity of 2 stroke added in the calculation.
A bit more power? Yes, for sure. A hill I often go up when holidaying in Wales, before I started adding 2 st., I would have to change down to as low as 2cnd near the top. Last year, when on the same hill, I did not need to go lower than 4th. I thought there was more power but needed something definite to prove it and that particular hill was it.
Regards,
Tony.
>> My second home is a Tranny <<
toniel
Postby toniel » Tue Feb 02, 2010 1:59 pm
Forgot to correct '' My second home WAS a Tranny ". I suppose I am a traitor now!
Tony.
toniel
Postby kjdiscos » Wed Jun 09, 2010 12:14 pm
i know a bit of a resseruction, but is anyone still doing the 2 stroke in the diesel ?,
If so any issues or results, Thinking of using it on a 53 plate transit connect tddi engine ?
kjdiscos
Postby darkbluevanman » Wed Jun 09, 2010 6:53 pm
toniel wrote:Forgot to correct '' My second home WAS a Tranny ". I suppose I am a traitor now!
Tony.
Nah... you only bought a piece of french muck camper designed for a midget!.... it's not like you sold out jesus or owt :wink:
My last adding of 2 stroke also included cetane booster and fuel cleaner?
darkbluevanman
Postby kimandjoshy » Thu Jun 10, 2010 1:28 pm
been running two oil in mine a 2010 140 t350 since new .less rattles slightly less fuel used .i had a vw caddy 1.9 and i cleaned out the shed and had a couple of 44 gallon drums of 20 year ol deisel . as i was getting my new transit anyway i used up the fuel and the power increase was fantastic .. old fuel more lubed so i started adding two oil in my transit vheaps better
kimandjoshy
Postby infinity1 » Sun Jan 15, 2012 12:54 pm
Anyone else adding the 2 stroke to a mk 6.?? 2ltr engine,very intrested in this as my step son has just got a twist and go moped so i seem to have bottles of 2 stroke sitting around all over the place!! Just could someone give me a rough idea of inclusion rates on it and can i just use the cheapo stufff from asda,tesco etc????
infinity1
Postby furnitureman » Tue Jan 17, 2012 10:53 am
Ive been running big blue on two stroke with a drop of acetone now for nearly a year and if I don't do it for a couple of fill ups it's definitely more rattle at start up and I do get a few mpg more out of the old girl
MK7 2006, 2.4 tdci, 140ps + TUNIT box = 165ps jumbo rwd known as "Big Blue" to the kids.
furnitureman
