Lvlyjubly123 wrote:yeah it is pal but what box should it have ?and will it bolt right on?
rover wrote:If it has T9 box that would be a bit oddSeeing as the YB has the same basic block as the pinto the van would have had a MT75 originally.
Rover.
Lvlyjubly123 wrote:rover wrote:If it has T9 box that would be a bit oddSeeing as the YB has the same basic block as the pinto the van would have had a MT75 originally.
Rover.
the van was a 2.5 di ....so should i put a mt75 box in it ??
MrMPuk wrote:Type9 and MT75 are rated to about the same output, I wouldn't bother doing anything till it goes wrong.
rover wrote:MrMPuk wrote:Type9 and MT75 are rated to about the same output, I wouldn't bother doing anything till it goes wrong.
They might be rated the same but I think we all know which is the stronger boxWhat I can fathom is why whoever did the conversion wouldnt have kept the MT75 in the first place
Are you sure its a Type Nine?
Rover.
