Good (cheap) sound deadening
Postby bennett418 » Thu Feb 16, 2012 11:09 am
I want to recarpet my van as its a camper and want to make journies quieter as have to shout to talk!
want a CHEAP sounds deadening/installation
any suggestions please ???
2.5di HiCube Camper
bennett418
Re: Good (cheap) sound deadening
Postby derv23 » Thu Feb 16, 2012 11:43 am
Sorry to hi-jack this thread, but i'm curious to find out the same as i have the noisy mk5 too :) . It doesn't bother me too much but if there is a cheap easy option i'm game 8)
MK5 Tourneo.
derv23
Postby spudmab » Thu Feb 16, 2012 1:24 pm
i always use flash tape, its ment for roofing but it works just like dyno mat,
http://search.diy.com/search#w=flashing tape&asug=flash
http://www.wickes.co.uk/invt/243011 ( i use this one myself)
just take the backing or heat it up a little then smooth it out and job done,
i got the ides from my mate who fits big audio systems for a living,
spudmab
Postby bennett418 » Thu Feb 16, 2012 2:18 pm
That Wickes one looks pretty good - ok £24 but 10m should be plenty!
Wonder if layer of that - then underlay then carpet should make quite a difference,
might even be able to get some on bulkhead too
how thick is the Wickes one???
2.5di HiCube Camper
bennett418
Postby BONESY » Thu Feb 16, 2012 4:13 pm
Use this inside the doors and on the roof http://www.wickes.co.uk/invt/243011
and this behind the plywood http://www.wickes.co.uk/red-plastic-wal ... vt/161235/
I done my swb Low top and yes it takes time to do it but makes a big difference
Try other DIY places as wickes are not always the cheapest ......
BONESY
Postby AndyG » Thu Feb 16, 2012 8:37 pm
You'll need two layers of the Wicks flashing if you want it as thick as Dynamat Xtreme :wink:
It'll also be quite smelly at first :twisted:
:arrow: viewtopic.php?f=13&t=28119
Postby bennett418 » Fri Feb 17, 2012 12:56 pm
Andyg wrote:You'll need two layers of the Wicks flashing if you want it as thick as Dynamat Xtreme :wink:
Smell wont bother as hopefully by time go camping will have gone.
How much was that dynamat stuff?
2.5di HiCube Camper
bennett418
Postby AndyG » Fri Feb 17, 2012 6:33 pm
Postby ake » Sat Feb 18, 2012 2:21 pm
Andyg wrote:Well, this one's a tad too expensive :?: :arrow:http://www.ebay.co.uk/itm/Dynamat-Xtrem ... 3a68a61041
But this is about what I paid :arrow:http://www.ebay.co.uk/itm/DYNAMAT-XTREM ... 2a1891d5f7
Wow, it must be good, Chip Foose has signed the box :D
