24v 2.9 V6 Cossie lump into a Mk3 190
Postby Guy88 » Tue Nov 07, 2006 6:24 pm
it will be suppoted the sames as the pinto was :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dipstick » Tue Nov 07, 2006 11:21 pm
Guy, i haven't seen a Pinto mount.... but i was thinking if 'could' use the ally Granada/Scorp mounts instead of the massive steel Ford Amby ones, then half the problems would go away ... i could connect up the oil return to the sump, and use the remote oil filter and cooler, no problem!
... cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Tue Nov 07, 2006 11:45 pm
dipstick wrote:Guy, i haven't seen a Pinto mount.... but i was thinking if 'could' use the ally Granada/Scorp mounts instead of the massive steel Ford Amby ones, then half the problems would go away ... i could connect up the oil return to the sump, and use the remote oil filter and cooler, no problem!
... cheers
i cant see exactly what problems you are having with the mounts :? cant you mod the mounts at all :?: as you have the proper mounts imo thats the way to go as the rubber cusion it much bigger than the pinto ones :D - im gonna have the same problems when i do mine, is it both or just one mount that is in the way :?: can you email me a photo showing the problem :?: im sure there must be a way round it :? :lol:
Image Image
Postby Guy88 » Tue Nov 07, 2006 11:46 pm
The pinto ones go up at 45 degrees. when i was speaking to big john he said about cutting them bending them vertical and using the ally mounts. apparently they are all in the right place. i will find out at the weekend :roll:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Tue Nov 07, 2006 11:51 pm
Guy88 wrote:cutting them bending them vertical and using the ally mounts. apparently they are all in the right place.
yeah thats what oxtony did :!: i suppose that its the same mount (engine) as used in the granny and the chassis mount will be stronger - the weakest link is the ally bit :?
the amby mounts are ott but i like that :lol:
Postby madmark » Wed Nov 08, 2006 4:54 am
use the amby mounts thats what they are built for! :wink:
2.9 engine mounts
Postby dipstick » Wed Nov 08, 2006 10:11 am
Luke Mark et al,
If you use the steel Amby mounts for your 24v,because they have this 'brace' that goes backwards to the adapter plate, they run very close to the sump. This prevents the oil return pipe from connecting to the sump, as the spigot sticks out from the sump by an inch or so.... :(
... and the oil filter/cooler remote is also a problem, again, due to the size and shape of the stel mount + brace.... it just gets in the way, because on the 12v motor these things are not present..... :(
i will dig a photo out in jiffy .....
cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby dipstick » Wed Nov 08, 2006 10:18 am
if you can see the photo above, you might notice the 'oval' oil return in the side of the sump, just dotted with some orange silicone....
...the spigot for this is just haning down on the end of the return pipe in front of the mount......
This will not bolt up to the sump with the Amby mount there... :-( but using the ally Scorp one would allow it to be fitted.....?
It only seems to be this side with the problems, the 'clutch' side seems OK so far ....?
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Wed Nov 08, 2006 1:26 pm
ah i see now :D still not a problem :? :lol: - can you weld it, its it cast :?: mabe cut out a hole there and weld a pipe in to get the strength back :!: or mabe space it (the mount) off the block to give clearance and reddrill the plate where it supports it - (i prefer the 1st idea) :!: is that the only problem :?:
Postby madmark » Wed Nov 08, 2006 1:32 pm
yer luke i was thinking the same thing, must be able to cut some out of the mount! :?
Postby Luke » Wed Nov 08, 2006 1:40 pm
would it be possable to blank it off and relocate the oil return somewhere else :?:
Postby dipstick » Wed Nov 08, 2006 2:19 pm
.... :-) on the money Luke.....
Yes that is what i think i will do .... blank it off (the hole in the sump) behind the mount then reroute the pipework downwards to the sump and drill and tap the sump to take the spigot.....
It is not under a great pressure, just gravity, so shouldn't have to stand too much .:-) ?
As an aside, does anyone know where i can find Transit engine mount rubbers, the rubber things with the two 10mm studs top and bottom.... Local Ford dealer has no stock... :-(
cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Wed Nov 08, 2006 8:55 pm
dipstick wrote:As an aside, does anyone know where i can find Transit engine mount rubbers, the rubber things with the two 10mm studs top and bottom
i wondered if they were the same as the Di ones :?
Postby dipstick » Thu Nov 09, 2006 9:43 am
... i have been to Ford, they have a different FINIS code,, the 2.9 to the 2.5Di ones, but i can't find any Di ones around, to look at ... one in Edinburgh according to Ford!!
Anyone know of a supplier at reasonable cost.....?
The Di lump is HEAVY, so i reckon the Di mount rubber has a shear factor enough to support the iron block + ally heads of the 24v OK...?
So, again, does anyone know where i can get Di engine mount rubbers from.....?
thanks again, ....... :-)
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Sun Dec 17, 2006 6:27 pm
just got to this stage with mine - but my mounts are different :? i think :? when its bolted up you can't see any of the hole :shock: and where yours has a single strengthning web mine has a double one :?
does yours also foul the water pipe coming out of the oil filter housing :?:
im thinking of remanufacturing the entire mount :x i'll see if i can get some photos of mine up :!:
