Engine Swap/Beef up
Engine Swap/Beef up
Postby Kevin Hawkins » Mon Aug 15, 2005 10:01 pm
I have recently come onto the Transit scene having purchased an '89 SWB petrol camper and would be very grateful for the expert advice from all you out there. The van is fitted with a pinto engine which is just so under powered (it has only done 24,000 miles).
a) can the pinto be beefed up?
b) if I change the engine what would you advise I change it to - I am not
bothered if it diesel or petrol at this stage.
I just want a vehicle that will keep up with todays traffic and I do not have to go through the gear box every time the van reaches an ant hill.
Kevin :roll: (not another ant hill)
Kevin Hawkins
Postby FredTransit » Mon Aug 15, 2005 10:13 pm
I am confused. A 2L in a SWB should be enough, unless your camper fittings and gear are made of lead! :lol: We have a 2L in a LWB panel Mk2, and still use her commercialy. She has a twin choke and 5 speed conversion and will still get to 70 loaded. We also have a minbus SWB with a pitiful VV carb and OD box which is a bit slower, but I have never had her fully loaded as we have only used her for film work. What gearbox do you have, and which carb?
if you change the engine, at 24,000 I'll have it!
FredTransit
Mk2 Trannyist
Postby madmark » Tue Aug 16, 2005 1:52 am
yes a twin choke carb conversion will give it some more oooomph from a cortina or capri etc! :)
Postby gazza » Tue Aug 16, 2005 10:41 am
the venerable pinto has plenty of tuning scope, just depends on what you want, i dodnt think a 180 bhp 2.1 pinto in a camper would make for a pleasent trip round the cotswolds :lol: if you are after more torque (puling power) you would be better with a v6, if you want more mpg you need a 2.5 d, petrol engined vans quiter but more thirsty, diesels more economical but louder than petrol. you have to way pros and cons. but in mean time find a carb / manifold off of a sierra cortina or capri, may need some setting up though, another good bet is a 4 branch manifold gets rid of the awful standard cast exhaust manifold, try a web search for capri care at drayton parslow near bletchley, he may be able to help you in your quest for a little more go!
gazza
Postby jay » Tue Aug 16, 2005 12:39 pm
change the head as transit engines are lower compression and have a differnt cam.car ones have slightly higher compression and a slighlty longer profile cam.or just put a performance cam in nothing to wild just enough so you will get more mid range torque.you wont want all thep ower at the high end.or to be extreme put a cosworth engine in it that will be one fast camper :twisted: :twisted:
mk1 connect tourneo
jay
Postby ovlov » Tue Aug 16, 2005 9:20 pm
:shock: Pinto in a swb could it a 1600 and not a 2lt :lol: :lol:
I want to live forever so far so good
ovlov
Postby bortaf » Tue Aug 16, 2005 11:46 pm
ovlov wrote::shock: Pinto in a swb could it a 1600 and not a 2lt :lol: :lol:
Not allways, the engine in me LBW minibus came from a SWB tranny (G reg) that was a 2.0 and so was one i scrapped a month or so back.
And me Mk2 is a SWB 2.0 :)
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby FredTransit » Wed Aug 17, 2005 9:47 am
Yeah minbuses, the engine we took out was a 2L, in a SWB. That was in there from new. It just depends what was originally ordered from new.
FredTransit
Mk2 Trannyist
