Tow bar conections???
Postby handymac » Sun May 20, 2012 11:38 am
Would I be right in thinking that the Mk6 has a loom connection for a tow bar socket?
I found a connection with a blanking plug in it at the back on the N/S. If so where could I get one of the plugs?
Thanks i advance for the wisdom :D
handymac
Re: Tow bar conections???
Postby ake » Sun May 20, 2012 12:15 pm
Very few are per wired, and if they are it comes under the van
Postby winterheating » Sun May 20, 2012 7:57 pm
Can the right/offside indicator be wired from the left/near side light cluster home..
winterheating
Postby stephenferguson » Sun May 20, 2012 8:00 pm
i too have this plug, its behind the light cluster, and thats what i thought it was for. ive been looking for a plug and play kit for it but had no luck, wonder whats its for if its not for the tow bar wiring??
mine is an 06 100ps with all the electrics so always though thats what it was... :?
2008, VW Transporter T5, T30, 6 Speed 130, Reflex Silver.
2006, 100 T280, MWB, Mid Roof, Moondust Silver. SOLD
Mk6-Mk7 Facelift Photos Here
stephenferguson
Postby winterheating » Sun May 20, 2012 8:02 pm
Isn't that plug for the reverse buzzer :?:
winterheating
Postby stephenferguson » Sun May 20, 2012 8:05 pm
winterheating wrote:Isn't that plug for the reverse buzzer :?:
Dont know, i was hoping tow bar so i could plug and play!
stephenferguson
Postby handymac » Mon May 21, 2012 12:35 am
Guys I will have a look.
If someone can give me a how to post a pic
then
i will
handymac
Postby ake » Mon May 21, 2012 6:32 am
I think you will more likely find that the unused plug is for the optional heated rear window and wiper. Even the Ford genuine trailer socket kit is connected infusing interrupter looms at the rear lights
Postby motorman116 » Mon May 21, 2012 6:55 am
stephenferguson wrote:i too have this plug, its behind the light cluster, and thats what i thought it was for. ive been looking for a plug and play kit for it but had no luck, wonder whats its for if its not for the tow bar wiring??
Got my plug and play kit from here..... http://www.towequipe.co.uk/itemlist.html
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby stephenferguson » Mon May 21, 2012 6:04 pm
So where did that plug in motorman? - the plug im talking about behind the passenger side rear light cluster??
stephenferguson
Postby motorman116 » Mon May 21, 2012 7:26 pm
You remove the wiring plug off the rear lights and plug the towbar wiring onto the lights then the vehicle lighting wiring plugs, plugs onto the towbar wiring connectors, and then there is a relay that goes behind the O/S/R Light unit, then a power wire. on the my van there was already a live wire behind the O/S/R Light. It was an easy job to fit, straight forward....
motorman116
Postby stephenferguson » Mon May 21, 2012 9:18 pm
8) cheers. that other plug must be the factory heated screen and wash wipe then as Ake said..
stephenferguson
Postby winterheating » Mon May 21, 2012 9:27 pm
So can the offside indicator be wired from the near side?..????
winterheating
Postby stephenferguson » Mon May 21, 2012 9:39 pm
not sure, at the minute, mines wired from the other side as i ran a wire over but this plug and play kit suggests u can, motorman mentions it needs a live, not sure what for tho?
stephenferguson
Postby mealic » Mon May 21, 2012 9:40 pm
Got mine from a company called Westfalia,dedicated kit,no hassle complete with loom ,warning buzzer,socket and comprehensive instructions.
`04 2.3 petrol/LPG
mealic
