bigjohnthomas wrote:Is the factory fitted one a bit sh*t then?
bigjohnthomas wrote:The other month the fob wouldn't let me in so I had to use the real key in the door and a siren went off till I started him
I will carry out further tests
Altransit wrote:
He did say that, but we tried it in his van, and found that you activated an entry delay bleeper when entering with a key, but I can't quite remember how we cancelled the delay before the alarm went off a few seconds later![]()
Mike S wrote:I've got the Cobra cat1 alarm Rob, no reason that it couldn't be fitted to your van from what I can see.
bigjohnthomas wrote:Just tried it ...unlock the door with the key he bleeped for a bit then alarm went off turn key in ignition and it shut him up
Would it of shut him up if I used "a key" ?
Punto443 wrote:Then spent 20 minutes trying to find a ninja's mask off the wee mans Lego man which I eventually found in his car seat that I had taken out the van.
Its Damn tricky to spot a ninja in a transit!![]()
Users browsing this forum: Google [Bot], oranjefan99
