Will these alloys fit on lowered transit? 18" x 8.5" ET40
Postby zombiechad » Thu Jul 12, 2012 4:28 pm
Hi, I am in the USA and I am looking to install 18"x8.5" ET40 wheels on a tall roof, LWB Transit Connect. I plan to lower the van as well and I don't want any rubbing. Any hope of this fitting? Is there a more ideal offset?
Thanks,
Chad
zombiechad
Re: Will these alloys fit on lowered transit? 18" x 8.5" ET
Postby g-man » Thu Jul 12, 2012 4:36 pm
hiya m8y :) should be ok with 8.5's with that offset but might be a bit close on rears to the inner arch......7's would defo clear
g-man
Postby zombiechad » Thu Jul 12, 2012 5:06 pm
g-man wrote:hiya m8y :) should be ok with 8.5's with that offset but might be a bit close on rears to the inner arch......7's would defo clear
Thanks for the reply! This may be a long shot, but does anyone have pictures of an 18"x8.5" ET40 on a lowered van?
zombiechad
Postby valetech » Thu Jul 12, 2012 5:14 pm
Ford use 18"x7.5j
But most people use the focus st wheel which is 18"x8j
Both have a et45
Both run very close to the rear inner arch felt panel
It's also a case of how low are you going
molested by:
19s is how we roll
valetech
Postby zombiechad » Thu Jul 12, 2012 5:52 pm
valetech wrote:Ford use 18"x7.5j
Both have a et45
How much lower is this(your?) van compared to stock? Are these the 18x8 et40 ST wheels? 225/45/18? Rubbing?
What about this one?
I'd be happy with these ride heights. I want the van to be usable but the stock ride height is too high.
zombiechad
Postby zombiechad » Thu Jul 12, 2012 5:54 pm
These are the wheels I am looking at fitting.
zombiechad
Postby valetech » Thu Jul 12, 2012 6:03 pm
first pic is my old van yes,does go lower than that.they are connect alloys 18"x7.5j et45 its around 4"to7" lower on the rear sportvans are lower from factory than a standard connect
second pic is a customer/forum member.
lowered the same as mine and running focus st 18x8j et45
have had no probs with the wheels rubbing
molested by:
19s is how we roll
valetech
Postby zombiechad » Thu Jul 12, 2012 6:10 pm
valetech wrote:first pic is my old van yes,does go lower than that.they are connect alloys 18"x7.5j et45 its around 4"to7" lower on the rear sportvans are lower from factory than a standard connect
4" to 7" is a big range relative to vehicle ride height! 8) So an extra inch in width may get close to the inner plastic arch in the rear. Has anyone trimmed this arch or spaced it? What about the front? Rubbing at full lock?
zombiechad
Postby Kent Discos » Fri Jul 13, 2012 1:50 pm
i fitted 5mm spacers on the front if mine just because i wanted to really... and no rubbing on the back at all.
Jack Wilson | 2017 Transit Custom 290 130PS from Absolute Vans
Kent Media Group - http://www.kentmediagroup.co.uk | Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Postby valetech » Fri Jul 13, 2012 3:19 pm
Sorry what am I talking about.
I got it wrong
You need et52.5
molested by:
19s is how we roll
valetech
Postby g-man » Fri Jul 13, 2012 5:16 pm
more likely to catch with 52.5's
g-man
Postby dazb40 » Fri Jul 13, 2012 5:38 pm
Could anyone tell me if these will fit without catching. Ill have a bid if its a green light :-) thanks
http://www.ebay.co.uk/itm/130726635425? ... _500wt_922
dazb40
Postby g-man » Fri Jul 13, 2012 5:45 pm
wheels will fit......... but those tyres are 9% bigger radius than standard and will put speedo way out
g-man
Postby dazb40 » Fri Jul 13, 2012 7:13 pm
Cheers for looking
dazb40
Postby valetech » Sat Jul 14, 2012 7:32 am
just found this,its a good pic to show the difference
thats my van next to g-man at north weald.
not sure what size g-mans wheels are 16" or 17"
et52.5 18x7.5j or 18x8j do not rub
molested by:
19s is how we roll
valetech
