Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Re: Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Postby Luke » Tue Aug 07, 2012 10:32 pm
decided to swap to my spare g/box - started to remove mine tonight but ran out of time - should be done before FF this weekend - fingers crossed the spare box is ok :mrgreen:
and (just for tim) ive also decided to go down the charge cooler route so purchased a charge cooler - more on that later :mrgreen:
Postby dieselhead123 » Tue Aug 07, 2012 10:43 pm
Luke wrote:decided to swap to my spare g/box - started to remove mine tonight but ran out of time - should be done before FF this weekend - fingers crossed the spare box is ok :mrgreen:
Sorry that I won't get to see the van again at FF this weekend, but I have other plans involving 'spark plugs' :lol:
I do hope the charge cooler is not the new one, you do know that one is a copy of the one fitted as standard to a Citroen CX DIESEL :lol: :lol:
Postby Luke » Thu Aug 09, 2012 11:17 pm
:lol: :lol: it's arrived - but it's damaged :(
i've managed to swap over the gearboxes - not a job i'd fancy doing again on my own :x - got it all running tonight but didnt have enough oil for it :roll: 6 litres in and its below minimum :? so i need to get some more before i drive it anywhere :)
hopefully i can get it before FF on sat (i need to use toyota type T4 special order stuff)
here's a nice pic of the 2 boxes lining up :mrgreen:
Postby AlanN » Fri Aug 10, 2012 7:53 am
You like cutting it fine Luke
Postby dieselhead123 » Fri Aug 10, 2012 8:29 am
Luke wrote: it's arrived - but it's damaged :(
You intending to run a separate radiator on that or through the engine cooling system?
Have fun at FF mate, see you at Mania 8)
Postby Luke » Fri Aug 10, 2012 8:53 am
AlanN wrote:You like cutting it fine Luke
yeah i seem to find myself doing it regular :roll: even more so this time - just ordered the oil it's being delivered sat morning so it'll be a fill up quick test drive then off to silverstone :lol: hope this box is ok :shock:
dieselhead123 wrote:You intending to run a separate radiator on that or through the engine cooling system?
i'm planning on a seperate rad - under the rear floor just in front of the back axle :| :D i dont think the engine cooling water temp would be anywhere near low enough, my main concern with mine is can i get enough air flow cooling under the floor :idea: everyone says i should cut holes in the front spoiler and mount the cooler there :shock: but thats just not gonna happen :lol:
Postby IgorVigor » Fri Aug 10, 2012 10:26 am
there should be plenty of air flow under the van :)
if your rad is facing down, you could make a small scoop to direct the air through it.....
and a slimline rad fan or two, wired through a inline thermoswitch might be a nice idea :D
IgorVigor
Postby Luke » Sat Aug 11, 2012 12:51 pm
i got the oil done in time for FF but a test drive and its bad news on the new box too it's just as bad :( :(
not sure if i'll get it to FF or not but i'll be there either way :D
Postby Luke » Sun Aug 12, 2012 10:05 pm
well to update i did take the van down to ford fair :D great weekend as always 8) 8)
glad i did but it's definatly no good :( fine just pottering but as soon as it see's some power it just slips :( i'm thinking of replacing the worn parts in the 1st box :idea: after a certain person convinced me it's an easy job :lol:
Postby MattBlackMinibus » Sun Aug 12, 2012 10:41 pm
Luke wrote:well to update i did take the van down to ford fair :D great weekend as always 8) 8)
Did you drive it there and back? That's a fair trek from yours ... Some shake down :!:
Your best off building up a good box yourself.
You're more than capable, and you'll know how to work on auto boxes then :idea:
Starting All Over Again
MattBlackMinibus
Postby Luke » Mon Aug 13, 2012 12:15 am
yeah i drove it all the way :D
Postby dieselhead123 » Mon Aug 13, 2012 11:14 am
Glad you got there mate and had a good time.
Postby MONSTER 0NE » Mon Aug 13, 2012 4:16 pm
It was nice to see it at the show yesterday under its own steam, and ive gotta say the dash is a work of art :lol: , and whats that at mania there will be a master class in rebuilding a toyota auto box by the auto box master AndyG :D
MONSTER 0NE
Postby MattBlackMinibus » Mon Aug 13, 2012 6:47 pm
MONSTER 0NE wrote: and whats that at mania there will be a master class in rebuilding a toyota auto box by the auto box master AndyG :D
I heard someone say that too ... so it must be true !!
MattBlackMinibus
Postby Luke » Mon Aug 13, 2012 10:03 pm
i'm hoping that andyg will have it sorted before then :mrgreen: :lol:
