can you run halogin spotlights off 12volt?
Postby staffy31 » Wed Aug 29, 2012 8:52 pm
hello does anyone know if you can run halogin spotlights from a liesure battery plz.. :roll:
staffy31
Re: can you run halogin spotlights off 12volt?
Postby jonochap » Wed Aug 29, 2012 9:51 pm
You can but the draw (250 volts plus) might drain your battery faster than you would like or be dimmer than you would hope...there are some very good led floods on the market though...others may answer this a little more technically, but this is my best reply :)
jonochap
Postby jonochap » Wed Aug 29, 2012 9:52 pm
It will also depend on the size of your leisure battery and how you charge it...
jonochap
Postby matthew2riches » Wed Aug 29, 2012 10:08 pm
You can buy 12v ones :wink:
matthew2riches
Postby jonochap » Wed Aug 29, 2012 10:09 pm
Phew! :)
jonochap
Postby fidget » Wed Aug 29, 2012 10:24 pm
if you are on about the spot lights for your home that sink into the ceiling, then most of the bulbs for them are 12v anyway, they run thru a transformer in the home, as for how long your battery would last, it would depend on how many spot lights and what wattage you use, cheep ones are normaly 50w bulbs, 20w bulds give less light but the battery will last longer from charge to charge.
my advise may not be right, but I like to give my 10p worth, and an answer even if wrong is nice to see.
Build: 05.03.1992
Series: 100L
Diesel 2.5 (70PS)
5-Speed Manual - MT75
Drive: RHD RWD
Axle: 4.56
Diamond White 73
fidget
Postby jonochap » Wed Aug 29, 2012 10:42 pm
Sorry chaps, saw spotlight and read flood light :)
jonochap
Postby staffy31 » Wed Aug 29, 2012 10:52 pm
fidget wrote:if you are on about the spot lights for your home that sink into the ceiling, then most of the bulbs for them are 12v anyway, they run thru a transformer in the home, as for how long your battery would last, it would depend on how many spot lights and what wattage you use, cheep ones are normaly 50w bulbs, 20w bulds give less light but the battery will last longer from charge to charge.
thanks a wonder if i could just remove the transformer n wire them up or best going lookin for some 12v led ones jst got sme from carboot brandnew inbox thats al for 2quid be nice to see them in the staffy wagon :lol: :lol:
staffy31
Postby fidget » Wed Aug 29, 2012 11:00 pm
the led ones are good, very low enery use, only about half a watt, the light they give off is not as good as halogens but in a van they are great, also you can change then for color changing led bulbs, BUT i have not seen any in 12v, but not really looked either. lol
as for just taking the transformer off ant using the lights, yes you can as they are wired in paralel, but check the wattage on the bulbs, most are supplyed out the box with 50w buld, in a line of 3, that would be pulling 150watts from your battery, that would be like leaving your headlights on, :D
Build: 05.03.1992
Series: 100L
Diesel 2.5 (70PS)
Drive: RHD RWD
Axle: 4.56
Diamond White 73
fidget
Postby staffy31 » Wed Aug 29, 2012 11:10 pm
fidget wrote:the led ones are good, very low enery use, only about half a watt, the light they give off is not as good as halogens but in a van they are great, also you can change then for color changing led bulbs, BUT i have not seen any in 12v, but not really looked either. lol
aye think i better stick to the low watt bulbs like dont wanna be killin me leisure battery i havent even got yet hee hee still could do with some veg oil in like from asda if ya had any tips :lol:
staffy31
Postby fidget » Wed Aug 29, 2012 11:15 pm
aye think i better stick to the low watt bulbs like dont wanna be killin me leisure battery i havent even got yet hee hee still could do with some veg oil in like from asda if ya had any tips :lol:[/quote]
just one of the many threads on veg oil,
viewtopic.php?f=4&t=113839
Build: 05.03.1992
Series: 100L
Diesel 2.5 (70PS)
Drive: RHD RWD
Axle: 4.56
Diamond White 73
fidget
Postby ake » Thu Aug 30, 2012 6:43 am
Find some 12volt SMD LEDs, they are far better than halogen lamps, and use about 5% of the energy, and have a much longer service life
Postby staffy31 » Thu Aug 30, 2012 8:21 am
ihear ya ake get some powerfull led from china etc that use hardly any power solar panels are looking like the futre :lol:
staffy31
Postby staffy31 » Tue Sep 11, 2012 1:24 pm
i went to go outdoors they said you can get a inverter 240-12v so should be able 2 use 240 downlights neebother just need to see how much what am ganna use becuase the cheapest inverter is 500watt output so run me lights of that and everything else to the battery should be spot on anyone open to sugestions
:D :lol: :roll:
staffy31
Postby captain hook » Tue Sep 11, 2012 10:50 pm
staffy31 wrote:i went to go outdoors they said you can get a inverter 240-12v so should be able 2 use 240 downlights neebother just need to see how much what am ganna use becuase the cheapest inverter is 500watt output so run me lights of that and everything else to the battery should be spot on anyone open to sugestions
:D :lol: :roll:
WTF :roll:
captain hook
