fioroe wrote:Id never have thought of doing a van as old as ours that colour but it looks great, really works well.
What will you do about the joins/seams where roof joins sides etc? Will be interested in this. Mine was covered in that silver bitumen lined stuff when i bought it 5 years ago & it still leaked was an awful job scraping & cleaning it off. 1st year i made the mistake of resealing it in silicone which didnt last long so following year i redid seams with sikoflex that caravan boat sealant.Ive never been brave enough to take all the trim off but instead clean trim, mask tape either side & then sikoflex over it. Its white so looks ok & it does the job & also trims still there if i change my mind or win the lottery & pay you to do it properly!!!
The seam across the roof where fibreglass luton dome meets aluminium roof ive replaced with sikoflex too.I do this each year to make sure its watertight. I'll look into topping it with tape & painting it with that roof sealant you used.
Also used lots of sikoflex to rebed in & seal all luton windows.
What about that ridiculous gutter bit on luton under windows above the front aluminium panel? it sits full of water up to join so i filled it with bodyfiller, painted it x3 then sikoflexed it at front & back edge to keep water out. seams to work.friend has a gargoyle style pipe off front corners of this gutter to keep rain off windscreen.
Looking forward to next stage
fioroe wrote:Body looks great, love the painting...what did you use for the ali back? Keep looking at mine thinking about doing it...did you water down to roller?
davev6newman wrote:fioroe wrote:Id never have thought of doing a van as old as ours that colour but it looks great, really works well.
That alu trim on the roof shouldnt give me any more trouble, but to be on the safe side when i used the resin based sealer on the roof i painted over them trims as well, as photo.
Yes that gutter piece does hold water on the luton, but again i painted it all with Evercryl, so it can hold as much water as it likes now, it wont leak.
I am actually thinking of painting the roof again, my neighbour bought some for his garage roof and bought too much, so i might relieve him of it! Trouble is tho its black.
All the rest of the alu trims around the body and windows ive bought a grey infill strip to cover up the screw heads, this will make it much tidier.fioroe wrote:Body looks great, love the painting...what did you use for the ali back? Keep looking at mine thinking about doing it...did you water down to roller?
I used Dulux Weathershield gloss that i had mixed up, it is quite runny anyhow so no need to thin it down. The primer was a solvent based automotive primer called Re-paint, i had to thin that down almost 50/50.
blue estate wrote:When you getting a ticket on it
