scangauge e
scangauge e
Postby Bo_selecta_44 » Mon Sep 17, 2012 8:40 pm
Hi all , after a bit of advise,can anyone here confirm that this scangauge e unit will work with my van , its a transit connect 2006 75ps 1.8 tddc, as i emailed the seller and they said maybe ! well what sort of answer is that ? i dont really want to waste £74 if it doesnt.Will my van have the OBDII connection point ?
Also has anyone here have one or the scangauge II and how do you get on with them ?
http://www.ebay.co.uk/itm/ScanGauge-E-F ... 3a79af5da7
Regards
Bo_selecta_44
Re: scangauge e
Postby Adam_84 » Tue Sep 18, 2012 2:43 pm
Hi, I'm pretty sure mine is the scangauge 2 and I find it comes in very useful seeing what mpg, actual speed, engine load, temp etc only thing that they do with changing is the average mpg as I feel it reads too quickly so if you've been getting 41.2mpg then go up a hill and it drops to 37mpg and you stop then it will read your last mpg figure not the course of the whole trip if that makes sense.
They are very good though to use for reading faults and I've found the colour matches the green of the dials and milometer
Adam_84
