Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Re: Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Postby bez » Sun Sep 16, 2012 12:58 am
Any more up dates
if in doubt flat out!
bez
Cosworth Powered
Cosworth Powered
Postby Luke » Mon Sep 17, 2012 10:32 pm
bez wrote:Any more up dates
not really mate - i've had a bit of time doing other jobs on other stuff :) i've welded on the previa key barrel (it's in a better position) i started to wire it in but its not as straight forward as i 1st though :roll: :lol:
Postby bez » Mon Sep 17, 2012 11:43 pm
Things never are pal that's why we do it
bez
Cosworth Powered
Cosworth Powered
Postby Luke » Fri Sep 21, 2012 5:15 pm
didnt get chance to update while the site was down but.......
managed a bit more the other day - fitted my opening drivers 1/4 window 8) thought it would be straight forward but it needed the brackets modding but nothing too bad - just need a passangers to match now :D
also moved the key so it starts of the previa barrel alll sorted now :D i also managed to weld the auto brake pedal on so it's got a large brake .......... not sure why never missed the normal one but its an auto 'must have' thing :| :mrgreen:
ive also started to trace out the entire wiring loom onto paper so i can go thorough and cut out the redundant wires - i thought i would have been able to find this on the net allready but i've looked for ages and can't find one :( weather i get it finished or not is a different matter as it's a bit of a task and i'm fed up of it allready :lol: but it will be nice to have as a diagnostic for the future :D
Postby Luke » Sun Oct 14, 2012 8:31 pm
not had a great deal of free time lately but i've managed to make a good start on the drawing, this is a photo of it, i'm pritty sure this would start and run the engine all thats left to finish off is the cruise control :D i've done a bit more since i took the picture btw the paper size is 4 A3 sheets selotaped together :lol:
decided to make the dash as it needs doing so i can mount all the gauges and run the wires to the correct lengths ect. i've been doing loads of sketches of how i want it to look, it needs to be retro and in keeping with the van style :D eventually it came down to these 2 - they are drawn to scale :D
in the end i chose the lower one as i think the top one looks a bit too basic :? even tho i may change my mind later :lol:
made a start today - i'm making it out of wood 1st - not sure it i will make a fibreglass mould or what but i can see how it looks when the wooden one is finished :D
this is how far i got :| it's not as easy as it looks - cutting the wood is no problem its just fitting it in when its all bolted together that needs thinking about :lol:
luckly woodwork was one of my favorite lessons at school :lol: i can't imagine how much this would cost to get someone else to do :shock: and getting it to turn out how i want would be a nightmare :roll:
Postby robbie.cee » Sun Oct 14, 2012 9:15 pm
:mrgreen:
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby AlanN » Wed Oct 17, 2012 11:16 pm
Blimey, you making your own circuit diagrams now :shock:
Postby ake » Sat Oct 20, 2012 8:20 pm
AlanN wrote:Blimey, you making your own circuit diagrams now :shock:
It's easier than following someone else's ;)
Postby Luke » Sat Oct 20, 2012 9:03 pm
:lol: yeah handy to do as it gets me used to the wiring and if i get any problems it'll be easier to fix :idea:
not done any more yet but i'm thinking of getting one of the early T-R-A-N-S-I-T badges to have on the left hand side of the dash :idea: 8) :?:
just posted a few q's here :arrow: viewtopic.php?f=3&t=117784
Postby madbri » Sun Oct 21, 2012 6:20 pm
u going to put some dark oak veneer over that loverly dash?
madbri
Postby Luke » Sun Oct 21, 2012 7:03 pm
madbri wrote:u going to put some dark oak veneer over that loverly dash?
no not really the style im looking for :) i'm thinking of covering it in black leather type fabric then the inserts in the same material but grey :idea:
hopefully it should look good :? :mrgreen:
Postby MattBlackMinibus » Sun Oct 21, 2012 9:17 pm
Luke wrote: i'm thinking of covering it in black leather type fabric then the inserts in the same material but grey :idea: hopefully it should look good :? :mrgreen:
Sounds good :idea:
Starting All Over Again
MattBlackMinibus
Postby Luke » Sun Nov 04, 2012 11:14 pm
dashboards coming on slowly - very time consuming making all the brackets :|
but the main progress is i've now bought another gearbox (i have 3 now) but this one is guaranteed working ok :D it was a bargain (well it will be if it works :roll: ) works out cheaper than rebuilding the other one - i'm still planning on stripping and rebuilding 1 but this will hopefully give me more time and if needed i can uprate it when i do :D
Postby belly » Mon Nov 05, 2012 7:57 pm
Good work Luke 8) If you need some larger sheets of paper let me know, there old posters but the back of them is plain :wink: Couple of questions for you though, how do you do it ? Do you have a time machine ? You have a family a full time job numerous projects and started a pretty successful forum :shock: I don't even have the time to do some very very simple bits to a newish van :(
belly
Kaiser Chief
Postby Luke » Fri Nov 30, 2012 8:11 pm
thanks belly but i think you've cursed me with those coments :lol: :lol: i've not had a minute since my last post :roll: - the old gearbox isnt out yet and i dont think i'll be getting much free time this weekend eithr :( :)
