24v 2.9 V6 Cossie lump into a Mk3 190
Postby Guy88 » Sun Dec 17, 2006 7:45 pm
My adaptor plate fouled the water pipe from the oil cooler :x
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dipstick » Mon Dec 18, 2006 10:54 am
Luke,
Re the engine mount rubbers.... i sourced a pair from the Van Place in Southgate (I think), London, all the mounting rubbers are roughly the same, so a pair of anyones will do.....
cheers :)
dipstick
Cosworth Powered
Cosworth Powered
Postby dipstick » Mon Dec 18, 2006 10:56 am
Guy,
do you have the remote water/oil cooler fitted....? Then yes, there is a problem ...! :(
I figured it would be easier to use a 'conventional' oil cooler mounted up front, and lose the water/oil cooler, then this might free up some room...?
good luck :)
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Mon Dec 18, 2006 11:20 am
I am going to remove the settl pipe and rout it wityh rubber pipe :wink:
The one behind the head is also a c*nt And there the important ones :roll: to the heater :lol: :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dipstick » Mon Dec 18, 2006 2:40 pm
Guy, yep, i pulled all the water pipes out of the Vee, i am going to reroute then 'the long way round' in 15mm copper and then back up to the heater matrix in rubber, messy but easier to fit up and fettle .... ! :)
cheers
dipstick
Cosworth Powered
Cosworth Powered
ex manifolds vs adapter plate...! :(
Postby dipstick » Tue Dec 19, 2006 5:20 pm
http://photobox.tiscali.co.uk/album/alb ... o=88304307
http://photobox.tiscali.co.uk/album/alb ... o=88304291
if you can see in these two images, the ex manifolds foul on the adapter plate!
i cannot grind away the plate as it supports the MT75 box there..... so has has anyone in this position got over it.....?
I know Guy is extending the manifolds off the head, how is that coming along? :)
anyone else got any ideas?..... Luke, Custom.... anyone ........?
cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Tue Dec 19, 2006 6:52 pm
Remember yours is a BOB. Mines a BOA and the manifolds are different.
Could you not cut the flange off and re weld it at the back or the last port :? :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dipstick » Wed Dec 20, 2006 12:23 pm
... bo11ox....
i did not realise that there were that many differences between BOA and BOB motors, i thought it was just the cam chains and cams.... :( ?
... yep, i think it will time to get out the angle grinder and chop off the ends of the manifolds.... :(
... how is your cast iron welding coming along...?:)
cheers,
ps have you got any digis of your manifold extension 'flanges' yet ...? :)
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Wed Dec 20, 2006 1:28 pm
i didnt realsie the BOB manifolds were different either :? are the ports the same :?:
i think like me, you have a few options
1. like guy - manifold extentions, but for mine i think they wont look neat enough
2. cut the flange off and weld it back on further back - even if you dont fancy welding it you could take it to any fab shop and it wouldnt be a problem
3. new manifolds - made from scratch - at the moment this is what im thinking of doing, but im a long way behind you - i havent even got my engine in yet. ive looked at a few pics and i reckon it wouldnt be too dificult but probly the hardest way round it
depends on the tools you have how confident you are with a welder and the finish you are aiming for :D
Postby dipstick » Wed Dec 20, 2006 1:54 pm
Luke,
i am investigating the differences between the BOA and BOB ex manifolds today ...
i think it will be best to either cut off the ex manifold flanges and reweld, or get new manifolds made up ....depending on the cost of each ..... i cannot weld cast iron, never tried anyway... :)
cheers ....
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Wed Dec 20, 2006 4:26 pm
Heres the tubes. I just gassed the flanges out and il weld them later :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dipstick » Wed Dec 20, 2006 5:35 pm
Guy, niiiice. ........ :)
I can see the difference now between the BOA and BOB manifolds, so are you going to put flanges on either ends of those oval 'tubes' and then sandwich the 'tubes' between the head and the manifolds?
good luck, cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby dipstick » Wed Dec 20, 2006 5:41 pm
ps, how did you get the 'tubes' oval, was it bought that way or did you 'squash' some round tube...? :)
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Wed Dec 20, 2006 5:51 pm
Yep flange on both ends :wink:
Its 40 mm tube pressed in a fly press :D I recomend seamless thou as it has a weak spot where the seam is
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dipstick » Wed Dec 20, 2006 5:57 pm
sounds good, 40mm dia tube, what wall thickness, about 3mm?
I have a place near me that do magic in stainless, i might pay them a visit before Christmas, see if they want to increase their Christmas bonus...?
:) cheers
dipstick
Cosworth Powered
Cosworth Powered
