24v 2.9 V6 Cossie lump into a Mk3 190
Postby Guy88 » Wed Dec 20, 2006 8:09 pm
Mine is 4mm. could realy do with being thicker :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dipstick » Thu Dec 21, 2006 12:33 pm
eek, 5mm wall thickness, that is a fly press and a half to squeeze that! :)
i shall look around this week, or after New Year now.... bloody holidays always get in the way ... :(
thanks for the advice, cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby MrMPuk » Thu Dec 21, 2006 1:36 pm
Bit of gas and you'll do it in a vice!
Postby dipstick » Thu Dec 21, 2006 4:15 pm
.... :-) hmmm, i could try.......
How long are the 'tubes' on yours going to be...? I have measured my manifolds against the head with the plate fitted to the block, and i reckon mine will need to be 3" plus...? :(
that seems awfully long to have to hang cast iron lumps off......
... i cannot get the flanges on the manifolds cut-and-shut either, Cosworth designed them so close to the heads, there is nothing to play with really... :(
i am thinking of biting the bullet and getting a pair of tubular manifolds in stainless....?
big gulp....
good luck :shock: :shock:
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Thu Dec 21, 2006 4:23 pm
Mine are 4"
Just got to file the ports now :roll:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dipstick » Thu Dec 21, 2006 4:37 pm
wow..... nice set up... :)
so you reckon the manifolds will' hang' off the tubes OK...? without risk of fracture??
For me it certainly seems the easiest and possibly cheapest way to go.... :)
good luck, let us know how you get on....
cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Thu Dec 21, 2006 5:23 pm
I dont see why it wont work. The manifolds havent been touched. THe tube wont break and as long as the welds are good they wont break. I reckon they will need replacing every few years due to the heat and cooling :wink:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby rover » Thu Dec 21, 2006 5:55 pm
If its mild steel Guy the flanges will warp :( I've had quarter inch plate warp before so I think its a bit optomistic to use 5mm......Hope I'm wrong!
Rover.
rover
Postby Guy88 » Thu Dec 21, 2006 6:20 pm
The flanges are 6mm plate. where the gasket will be is the same as where the tube is welded on so hopefully the tube may hold it.
We shall see :roll: :roll:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Thu Dec 21, 2006 6:48 pm
nice one guy 8)
i think it will be ok you could easly weld some strengthning lugs in from the top of each flange :D
Postby rover » Thu Dec 21, 2006 8:39 pm
It might be an idea to make up a specer to go between the downpipes and the manifold and weld a bracket to that, then bolt it up to the engine block at the bottom, creating a sort of cantelever effect :?: That will take the strain off your extensions pretty much altogether, then you only need to worry about lateral strain rather than vertical.
It made sense to me when I thought of it anyway, not sure it came over very well though :?
Rover.
rover
Postby Guy88 » Thu Dec 21, 2006 8:59 pm
I understand rover :D
I was thinking of that. Weld one end to the bottom or the manifold and bolt it to the engine mount. Somthing like that anyway :P :roll:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby OxtonyxO » Fri Dec 22, 2006 12:54 pm
guy there is a bloke making his own manifolds on ford power , have a look.
http://www.fordpower-uk.co.uk/index.php?showtopic=1716
also in this month performace ford is a topboss ad with custom manifolds howerver they are big bucks 500 up
and just a quick question what did you do with the brake servo pipe and the power streeing pump
mine is getting close now :D
OxtonyxO
Postby Guy88 » Fri Dec 22, 2006 1:21 pm
Brake servo vacuum is connected to the pipe above where the EGR connects to the plenum :wink:
Whats up with the power steering :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby OxtonyxO » Fri Dec 22, 2006 1:25 pm
brakes that what i had done! just checking
as for the power streeing what parts did you use where as the pipes are not long enough as the pump is on the wrong side
OxtonyxO
