Mk5 conversion - second or auxilliary battery?
Re: Mk5 conversion - second or auxilliary battery?
Postby ake » Sat Nov 10, 2012 10:10 am
All autos had twins as standard, as did vans with factory extras
Postby triffic » Sat Nov 10, 2012 6:17 pm
ake wrote:All autos had twins as standard, as did vans with factory extras
Ah, that would explain it. Mine's an auto, while the other person who I checked with has a manual box. His is configured as an auxilliary battery, and is not used as a starter battery.
I'm guessing that the reason to double up on an auto is not because they are any harder to start, but because you can't push start them.
triffic
Postby ake » Sat Nov 10, 2012 6:23 pm
Yeah I think that's it
Postby crazylegsvan » Sun Nov 18, 2012 8:08 pm
so the two batteries I have must be cos its ex bt and has a diesel heater. would they both be starting batteries or would one just be for the extras?
crazylegsvan
Postby ake » Mon Nov 19, 2012 6:19 pm
crazylegsvan wrote:so the two batteries I have must be cos its ex bt and has a diesel heater. would they both be starting batteries or would one just be for the extras?
Most likely both for starting, but have a look at the wiring to check
Postby triffic » Tue Nov 20, 2012 6:34 pm
As above, only checking the wiring will be conclusive, but if it's got a manual box (ex-BT means it will have) then it may well be an auxiliary battery, not a starter.
Take a look at the photo earlier in the thread - if you don't have that extra junction on the starter motor solenoid then it's probably an auxiliary.
triffic
