Connect split bulkhead pin locator?
Postby gardeningconnect » Sun Nov 25, 2012 7:07 pm
In my connect I have a split bulkhead,the hinged side keeps rattling as the pin has nothing to keep it in place. (it just sits in an oval hole which allows it to move and concequently rattles about) Is there something that the spring loaded pin should lock in to? Thanks.
gardeningconnect
Re: Connect split bulkhead pin locator?
Postby Lefty64 » Sun Nov 25, 2012 7:46 pm
Not sure what you're asking about. :roll:
The floor hole should have a rubber 'blind' grommet insert.
The retractable pin should have a straight sided rubber ferrule on the end.
2007 T230LX LWB (110PS) with aircon.
Vans are designed for people with imagination. Cars are so limiting ... what can you do with them?
Lefty64
