ake wrote:I reckon your front battery may be dying
t2myd wrote:My dad had same lights on his ,turned out it was the abs module
CH1 wrote:t2myd wrote:My dad had same lights on his ,turned out it was the abs module
How much did that cost to replace???
ake wrote:Stop panicking
CH1 wrote:Turned out to be crank pulley, rubber is braking up causing the outer part of the pulley to stand still hense the belt not turning alternator, water pump etc, changing it tomorrow
blue estate wrote:CH1 wrote:Turned out to be crank pulley, rubber is braking up causing the outer part of the pulley to stand still hense the belt not turning alternator, water pump etc, changing it tomorrow
you need 15mm socket and breaker bar
CH1 wrote:blue estate wrote:CH1 wrote:Turned out to be crank pulley, rubber is braking up causing the outer part of the pulley to stand still hense the belt not turning alternator, water pump etc, changing it tomorrow
This happened to you didnt it ???? I am going to take the front of the van off, grill, radiator etc, is that the easiest way to do it ???
blue estate wrote:Don't need to there's enough clearance just as it's 3 thin bolts not 1 thick one
